Re:Internet connectivity issue due to routing loop
ambivert skill
I have Internet browsing issue from their LAN on site D router what I have diagnose from my end issue is routing loop. Steps that I have taken.
1.I can ping from My PC to WAN Interface of site D and can take remote login into it’s WAN interface.
2 .I can trace route form site D to 8.8.8.8 DNS  and I can ping to internal DNS server as well  external server.
But when I try to ping LAN interface of site D it gives “TTL Expired in Transit” and the same response I got from other sites which are connected to site C (like we have site D connected to it).
By this message it means that there is some kind of loop in the network so please guide me how to resolve this issue and for your information we have static routes currently working in our network.
blau grana
Level 7
Level 7
If there is loop you should see it in output of traceroute LAN IP [site D].
Can you post this output?
Best Regards
Please rate helpful posts
Best Regards Please rate all helpful posts and close solved questions
Yes Transit Failed because of loops or incorrect routes.
Traceroute and check on which hop its is causing .
Jawad
ambivert skill
Thanks to both of I have resolved the issue it's due to incorrect routes.
Ambivert
