Re-Route Traffic
kuldeep.kaur
I would like our exchange traffic to go out a particular interface of a router. Could you please let me know how to do it. Please give me the commands.
Tks
mohammedmahmoud
Level 11
Level 11
You can use PBR (Policy Based Routing).
Policy-Based Routing
http://www.cisco.com/warp/public/732/Tech/plicy_wp.htm
Configuring Policy-Based Routing
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fqos_c/fqcprt1/qcfpbr.htm
Example:
access-list 1 permit
interface ethernet 1
ip policy route-map exch
route-map exch permit 10
match ip address 1
set ip next-hop
HTH,
Mohammed Mahmoud.
spremkumar
Level 9
Level 9
You can do this with policy based routing feature available in router.
You just need to match the traffic which requires to be re routed once you are done with that define the interface which it needs to use to exit out of the network and apply the policy..
Do refer the below link for more info on configuring up the same .
http://www.cisco.com/en/US/products/hw/routers/ps380/prod_models_comparison.html
regds
