Really stupid Q, re: Routing one IP away from a connected subnet..
graham smart
Hi guys,
Got an odd issue that I just cant seem to get fixed.
I have lets say a /24 directly connected via a vlan on a C6500 in the network.
I'm trying to migrate some servers/devices away from it , however I need to move parts of it away bit by bit ( For example a /32 or a /30  that make up the /24 )
Ive tried a direct ip route x.x.x.x 255.255.255.255 y.y.y.y     and even a ip route x.x.x.x 255.255.255.255 y.y.y.y 1
Yet it still prefers the directly connected range ( as I pretty much expected. )
Is there any way I get it to prefer a static route over a directly connected?
As what I try doesnt work.
-Graham
Please note: My comments are simply suggestions. I cannot be held liable for any loss of data, life or marbles due to following my instructions.
Got a website? Need some live chat software?
Live chat software for websites. Increase sales.
-Graham
Exactly!
So the directly connected /27  beats the BGP /19 as expected.
You need to get /32 (or /28 at least) either via BGP or statically configured.
HTH,
Milan
13 Replies 13
cadet alain
there is no way to make a static route prefered over a directly connected route.
I don't really understand what you mean by move parts bit by bit. Can you be more precise about what you want to achieve.
Regards.
Alain
I have a network on a Vlan (/24) that contains a lot of devices / servers.
I'm moving these to another part of my network ( Servers have new addresses but with a secondary IP of the one on the old network )
Ideally, I would like to move each IP bit by bit to the new network..
Ie:
ip route currentIP 255.255.255.255 newserverIPsomewhereElse
This would then mean that trafic for the specific IP would go to the new place while traffic for the rest of the connected /24 would carry on going where ity is currently..
I was hopeing because the /32 is more specific it would hold weight ( It does on the rest of the network ) but if you are on a device connected to the same switch as the directly connected range, It ignores the static and still routes to the connected range.
Ideally I want to set the /32 to have a better AD than the same IP in the connected range. ( if that makes sense? lol )
-Graham
-Graham
milan.kulik
Level 10
Level 10
as "longest match wins" within the routing table, I guess the host static route might work?
I even think I was using something similar several years ago but can't remember details.
I belive there was some trick - the next-hop needs to be in a different subnet or something like that...
What does "show ip route x.x.x.x" command display when you enter your
ip route x.x.x.x 255.255.255.255 y.y.y.y command?
There might also be a problem with  routing the packets back, as the moved server still keeps the original mask and default gateway configured, so you need another device configured with the same IP address as your original router?
HTH,
Milan
Hmm..
Routing outside of the switch holding the /24 is ok.. The rest of the network gets the /32 update via BGP and routes fine ( So from the internet, Access to the new server is ok. )
Its simply the routing on the local router thats a pain and takes the connected over the static.
Ie:
even if I put the static on the C6500 that has the connected range, A show ip route shows the IP is via connected ( rather than out via the static )
Im wondering if a static pointing to the switches egress interface might fix it .. This would mean a smaller prefix is via a psudo interface.. Hmm...
May give that a try.
-Graham
-Graham
Damn,
Doesnt work.
Ive found out what needs to be done to fix it though!
If I add the /32 to the next hope of the device holding the IP ( in the other location ) BGP updates the network fine.
The issue is that the /24 is directly connected on the old switch.
So,
To fix it.
I need to get the old switch to follow the route in BGP rather than the route for the cirectly connected /24
Any ideas how I can get the switch to prefer the ./32 in the BGP table over the /24 directly connected?
-Graham
-Graham
a host static should work on the old L3 switch.
At least if it behaves the same way as routers.
I tested in my lab (no L3 switch available) on a  Cisco 1812 router:
interface FastEthernet0
ip address 10.1.1.1 255.255.255.0
interface FastEthernet1
ip address 169.254.185.210 255.255.255.0
ip route 10.1.1.3 255.255.255.255 169.254.185.212
1812#sh ip route
S       10.1.1.3/32 [1/0] via 169.254.185.212
C       10.1.1.0/24 is directly connected, FastEthernet0
1812#sh ip cef 10.1.1.3
10.1.1.3/32, version 43, epoch 0, cached adjacency 169.254.185.212
0 packets, 0 bytes
via 169.254.185.212, 0 dependencies, recursive
next hop 169.254.185.212, FastEthernet1 via 169.254.185.212/32
valid cached adjacency
BR,
Milan
This is the problem I get on the "Old switch"
Switch#sh ip cef xxx.125.94.168
xxx.125.94.160/27, version 813430, epoch 0, attached, connected
0 packets, 0 bytes
  tag information set, all rewrites inheritted
    local tag: implicit-null
  via Vlan504, 2 dependencies
    valid glean adjacency
The issue that its taking the Connected route rather than the more specific route that is in BGP...
I know this is normal behaviour.. Just cant figure out how to force it to follow the route learned via BGP
-Graham
-Graham
what does sh ip bgp xxx.125.94.168
display exactly on the Switch?
BR,
Milan
IIts got the supernet from its RR's
Switch#sh ip bgp xxx.125.94.168
BGP routing table entry for xxx.125.64.0/19, version 47919259
Paths: (2 available, best #2, table Default-IP-Routing-Table)
  Not advertised to any peer
  Local
   xxx.125.95.10 (metric 21) from xxx.125.76.135 xxx.125.76.135)
      Origin IGP, metric 0, localpref 100, valid, internal
      Originator: xxx.125.95.10, Cluster list: xxx.125.76.135
  Local
    xxx.125.95.10 (metric 21) from xxx.125.76.131 (xxx.125.76.131)
      Origin IGP, metric 0, localpref 100, valid, internal, best
      Originator: xxx.125.95.10, Cluster list:xxx.125.76.131
Hmmm. Must mean that its summerizing the /32 from the rest of the network somehwere..
interesting.
-Graham
-Graham
Exactly!
HTH,
Milan
Sorry if I'm not understanding correctly but I believe you mentioned that the device you are moving is getting a new primary ip while maintaining the original ip as a secondary address? If so, why not just configure a NAT from the old IP to the new and allow routing to behave normally? I've never done it but it seems like it would work.
The command would be:
ip NAT inside source static [oldip] [newip]
Hi Josh,
NAT isnt really an option in this scenario. We are working with internet IP's across multiple router(C6500) switches across a large OSPF & BGP core.
The problem is that I have servers attached to one vlan hanging off one 6500, These are being migrated to new servers on a different 6500 thats geographically diverse to the other and ar eon "new" addresses.
The reason for the thread was to see how plausable it is to route a /32 out of the /27 or whatever and have traffic on the local device take the specific /32 over the locally connected /27.
As Milan has mentioned. The problem is essentially that BGP simply isnt handing the /32 to the local device as its being summarised somewhere on my network.
As the fix probably requires more effort compared to the risks and goals. I probably wont bother re-routing and just update everything for the new addresses.
Ty for your ideas.
-Graham
-Graham
