reason for RP Switchover
mayambanzumba
I am investigating why a RP switched over to a redundat RP.
The router software version is:10000 Software (C10K2-P11-M), Version 12.2(31)SB3c. From the show tech it seems that a bus error caused the problem. I have include a stack trace from the system failure.
------------------ show version ------------------
Cisco IOS Software, 10000 Software (C10K2-P11-M), Version 12.2(31)SB3c, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Mon 21-May-07 13:36 by pwade
ROM: System Bootstrap, Version 12.0(20020314:211744) [REL-pulsar_sx.ios-rommon 112], DEVELOPMENT SOFTWARE
Router uptime is 1 week, 5 days, 7 hours, 24 minutes
Uptime for this control processor is 1 week, 5 days, 7 hours, 21 minutes
System returned to ROM by SSO Switchover at 01:22:18 BST Wed Jun 20 2007
System restarted at 01:22:33 BST Wed Jun 20 2007
System image file is "disk0:c10k2-p11-mz.122-31.SB3c.bin"
Last reload reason: Unknown reason
Cisco C10008 (PRE2-RP) processor with 950271K/94208K bytes of memory.
R7000 CPU at 500Mhz, Implementation 0x27, Rev 5.1, 256KB L2, 8192KB L3 Cache
Backplane version 1.0, 8 slot
Last reset from register reset
PXF processor tmc0 is running.
PXF processor tmc1 is running.
PXF processor tmc2 is running.
PXF processor tmc3 is running.
1 FastEthernet interface
4 Gigabit Ethernet interfaces
24 ATM interfaces
2045K bytes of non-volatile configuration memory.
62976K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
65536K bytes of Flash internal SIMM (Sector size 512KB).
Standby is up
Standby has 1044480K bytes of memory
Redundant RP last failure info as reported by Standby:
bus error at PC 0x606814B0, address 0x2000034
Image text-base: 0x60011470, data-base: 0x62C00000
Stack trace from system failure:
FP: 0x70C102B8, RA: 0x606814B0
FP: 0x70C102F0, RA: 0x60681890
FP: 0x70C10310, RA: 0x604890B0
FP: 0x70C10330, RA: 0x6048B1BC
FP: 0x70C10348, RA: 0x60C3CBB0
FP: 0x70C10368, RA: 0x60C3D10C
FP: 0x70C10380, RA: 0x60C2EADC
FP: 0x70C103C0, RA: 0x60C2EB44
...end of Redundant RP failure info.
Configuration register is 0x102
------------------ show region ------------------
Region Manager:
Start End Size(b) Class Media Name
0x1A000000 0x1FBFFFFF 96468992 Iomem R/W iomem_cwt:(iomem2)
0x20000000 0x3FFFFFFB 536870908 Local R/W heap3
0x60000000 0x6FFFFFFF 268435456 Local R/W main
0x60011470 0x62BFFFFF 46066576 IText R/O main:text
0x62C00000 0x62F34A3F 3361344 IData R/W main:data
0x62F34A40 0x635A93BF 6769024 IBss R/W main:bss
0x635A93C0 0x6FFFFBFB 212166716 Local R/W main:heap
0x6FFFFC00 0x6FFFFFFF 1024 IMAGE R/W main:IVFS
0x70000000 0x79FFFFFB 167772156 Local R/W heap2
0x7A000000 0x7FBFFFFF 96468992 Iomem R/W iomem_cwt
0x80000000 0x8FFFFFFF 268435456 Local R/W main:(main_k0)
0xA0000000 0xAFFFFFFF 268435456 Local R/W main:(main_k1)
I would like to know what can be done to fix this.
aghaznavi
Level 5
Level 5
Both RPs are running Cisco IOS Software, and the primary RP crashes due to a software failure, or a catastrophic hardware failure. The table below contains detailed information on the type of software or catastrophic hardware failures that can cause an RP switchover.
http://www.cisco.com/en/US/products/hw/switches/ps718/products_tech_note09186a0080094b81.shtml#switch
