Recommendation for DCI Routing Protocol over Layer 2 Point-To-Point Circuit
nsti_0682
I have two data centers that I'm setting up. Two ELINE Point-to-point (Layer 2) circuits were ordered for the DCI between them. What routing protocol should I use across these WAN circuits...? I was originally planning on using EIGRP to keep the routing domain as simple as possible since they already run EIGRP as their IGP but because one of these circuits is 200Mb and another is 100Mb I'm now leaning towards BGP for traffic engineering purposes. Thoughts?
Hitesh Vinzoda
Level 4
Level 4
Hi you can use EIGRP with variance to do unequal cost load balancing
and use BGP to achieve that too using dmz link bandwidth
http://www.cisco.com/c/en/us/td/docs/ios/12_2s/feature/guide/fsbgplb.html
Configuring BGP Link Bandwidth
To configure the BGP Link Bandwidth feature, perform the steps in this section.
SUMMARY STEPS
1. enable
2. configure {terminal | memory | network}
3. router bgp as-number
4. address-family ipv4 [mdt | multicast | tunnel | unicast [vrf vrf-name] | vrf vrf-name] | ipv6 [multicast | unicast] | vpnv4 [unicast]
5. bgp dmzlink-bw
6. neighbor ip-address dmzlink-bw
7. neighbor ip-address send-community [both | extended | standard]
8. end
Hitesh
Please rate useful posts
