Reconnection 819 Router after connection failure
casper999
Hi all,
I have a Cisco 819 WAN Router (C819 Secure M2M GW (non-US) 3.7G HSPA+ R7 w/SMS/GPS).
Software: Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.2(2)T, RELEASE SOFTWARE (fc1)
For dialing in at my Provider (T-mobile Germany), I use the following chat-script:
chat-script gsm "" ATZ "" AT+CGDCONT=1 "OK" "AT!SCACT=1,1" TIMEOUT 60 "OK" "ATD*99#" "CONNECT"
Dial-In is successful after Reboot.
Now, i want to simulate a conenction fault, e.g. termination by mobile provider.
So I used the command "clear int cellular 0".
After that, The router can't dial in again.
Debug shows:
Dec  7 11:04:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to down
Dec  7 11:04:14: CHAT3: Attempting async line dialer script
Dec  7 11:04:14: CHAT3: Dialing using Modem script: gsm & System script: none
Dec  7 11:04:14: CHAT3: process started
Dec  7 11:04:14: CHAT3: Asserting DTR
Dec  7 11:04:14: CHAT3: Chat script gsm started
Dec  7 11:04:14: CHAT3: Sending string: ATZ
Dec  7 11:04:14: CHAT3: Sending string: AT+CGDCONT=1
Dec  7 11:04:14: CHAT3: Expecting string: OK
Dec  7 11:04:19: CHAT3: Timeout expecting: OK
Dec  7 11:04:19: CHAT3: Chat script gsm finished, status = Connection timed out; remote host not responding
Is the "clear interface cellular 0" the wrong way to test this, or why can't the Router reconnect?
The only solution is a reboot, but that is not the best option. The router should automatically redial.
Any ideas?
Thanks in advance!
i think i have a solution for your problem.
You need another chat script.
chat-script gsm "" "AT!SCACT=1,1" TIMEOUT 60 "OK"
This Solution works fine with the german t-mobile.
https://supportforums.cisco.com/docs/DOC-18957
Kind regards
Stefan
10 Replies 10
aidacruises
Hello casper999,
would you be so kind and share your cellular config? I do have the same router (C819 with HSPA+/R7) and try to connect to T-Mobile with the same error (Timeout Expecting OK).
Thank you in advance.
Mathias
Hello Mathias,
my solution is to manually reset the modem with the command
    test cellular 0 modem-reset
To enable such reset-commands, you need to configure "service internal" previosly in your router-configuration.
But I am still not sure, whether this test-scenario with "clear int cellular 0" is realistic.
Carsten
Hi Carsten,
thanks - same is "working" for me. As soon as the cellular connection is down it will only come up again after a device reload or your described procedure via modem-reset.
What is your intention, is this a software/firmware issue (upgrade needed?) or a bug or configuration issue?
Here my config lines:
cellular 0 gsm profile create 1 internet.t-mobile chap dummy dummy
chat-script hspaplus "" ATZ "" AT+CGDCONT=1 "OK" "AT!SCACT=1,1" TIMEOUT 60 "OK" "ATD*99#" "CONNECT"
interface Cellular0
ip address negotiated
encapsulation slip
dialer in-band
dialer string hspaplus
dialer-group 1
async mode interactive
ip route 0.0.0.0 0.0.0.0 Cellular0
dialer-list 1 protocol ip permit
line 3
exec-timeout 0 0
script dialer hspaplus
modem InOut
Mathias
I upgraded to the newset firmware, but it's still the same.
Did you simulate an error with "clear int cellular 0" or did you experience connection problems during normal operation?
If this error is only together with "clear int cellular 0" this might be a bad mechanism to test a failure.
I do have the issue after every normal lost connection - meaning I do not do any clear, just waiting for the next 3G connection loss...
Good Morning Carsten,
I'm now working with following IPSLA + EEM script to work around the issue:
ip sla 1
 icmp-echo X.X.X.X
frequency 5 ip sla schedule 1 life forever start-time now ip sla reaction-configuration 1 react timeout threshold-type consecutive  action-type trapAndTrigger ip sla logging traps ! event manager applet IPSLA1_EEM_SCRIPT event snmp oid 1.3.6.1.4.1.9.9.42.1.2.9.1.6.1 get-type exact entry-op lt entry-val "2" poll-interval 60 trigger occurs 1 period 60 action 01.0 syslog msg "IPSLA1 timeout, reset 3G modem via EEM script" action 02.0 cli command "enable" action 03.0 cli command "test cellular 0 modem-reset"
SMNP OID needs to be in the form 1.3.6.1.4.1.9.9.42.1.2.9.1.6.x, where x is the ip sla ID.
Mathias
Hi Mathias,
thank for the script. A colleague in my company developed the following script as a workaround.
ip sla 1
icmp-echo xx.xx.xx.xx source-ip yy.yy.yy.yy
frequency 120
event manager applet EnableCHATDebugging
event syslog occurs 1 pattern "%SYS-5-RESTART"
action 1.0 cli command "enable"
action 2.0 cli command "debug chat"
event manager applet EEM-Watchdog-modem-reset
event syslog occurs 3 pattern "Chat script gsm finished, status = Connection timed out; remote host not responding" period 300
action 2.0 cli command "test cellular 0 modem-reset"
action 3.0 info type routername
action 4.0 syslog priority informational msg "EEM Watchdog cellular modem reset on $_info_routername"
It seems, that not many people are using this router in such a configuration, especially with tcom.
Perhaps we can exchange further experiences with this router in the future directly???
Kind regards
Stefan
Hi Stefan,
thank you.
This works for german t-mobile as like as german vodafone.
Kind regards
Carsten
ted reese
I have this same interfaces in my 2911 ISR and when there is cell maintenace from my provider AT&T and my SIM becomes un-registered the only way I can bring it back is a reload.  I've debugged and my cel 0/2/0 interfaces shows as not responding:
%CELLWAN-2-SEND_TIMEOUT: Cellular0/2/0 not responding
The chat string is getting initiated but keeps show the connection times out:
CHAT0/2/0: Chat script HSPA finished, status = Connection timed out; remote host not responding
I can still send SMS to this interface but none of the solutions above seem to restart my connection.  Any thoughts on this one?
If we find something to restart the connection than I could use EEM to run the script.  It seems like the dialer doesn't know how to reach AT&T:
Ce0/2/0 - dialer type = IN-BAND ASYNC NO-PARITY
Idle timer (30 secs), Fast idle timer (20 secs)
Wait for carrier (30 secs), Re-enable (15 secs)
Dialer state is enabling
Dial reason: ip (s=99.0.0.0, d=0.240.0.212)
Time until interface enabled 9 secs
Dial String      Successes   Failures    Last DNIS   Last status
HSPA                     1        248    00:01:05           failed   Default
Thank you,
Ted
