Router configured by SNMP or Syslog server?
Pradeep H A
Iam seeing these logs on the router: (Replaced IP address with x.x.x.x)
Nov  1 09:41:42: %SYS-5-CONFIG_I: Configured from tftp://x.x.x.x/R1-83137.conf by console
R1#sh run | i x.x.x.x
logging x.x.x.x
snmp-server host x.x.x.x gps21P28S19J17JH
ntp server x.x.x.x
R1#sh run
Building configuration...
Current configuration : 33705 bytes
! Last configuration change at 09:41:42 GMT Thu Nov 1 2012
! NVRAM config last updated at 02:18:44 GMT Thu Nov 1 2012
R1#show startup-config
Using 12816 out of 262136 bytes, uncompressed size = 33706 bytes
Uncompressed configuration from 12816 bytes to 33706 bytes
! Last configuration change at 09:42:50 GMT Wed Oct 31 2012
My Question:
1. The log says tftp server @ x.x.x.x configured the router & show run shows the config was indeed changed at the same time! Can someone tell me Why this is happening?
2. However the log seem to have affected only the running-config not startup-config! Why?
Thanks a lot in advance!
Jeff Van Houten
Level 5
Level 5
The running config was overwritten by someone using a config from a Tftp server. The reason the startup config hasn't been written is because it wasn't saved.
Hi Jeff,
I wonder how that could have happened? because we have TACACS+ configured on all our routers & in case anybody chages or updates configuration it should show the user id like the one below:
Nov 1 18:40:25: %SYS-5-CONFIG_I: Configured from console by on vty0
But the logs shown above doesnt show any user id which makes me think it must be some automated feature of SNMP or Syslog or NTP?
Pradeep H A
One more related log & SNMP information. hope this might help:
From Cisco Error message decoder:
%SYS-4-SNMP_HOSTCONFIGSET: SNMP hostConfigSet request. Loading configuration from [IP_address]
SNMP is reading the host configuration from a network host.
Recommended Action: This is an informational message only. No action is required.
Related documents- No specific documents apply to this error message.
From SNMP Object Navigator:
Specific Object Information
ObjecthostConfigSet
OID1.3.6.1.4.1.9.2.1.53
Type DisplayString
Permissionwrite-only
Statusobsolete
MIB OLD-CISCO-SYS-MIB ;                                   -        View Supporting Images
Description"Cause the loading of a new host-confg file
using TFTP."
Well that would mean indeed our SNMP server uploaded configuration to our router.
But still want to know whether its a automated scheduled task & what would be the purpose one would implement it in real networks?
