12-16-2019 02:07 PM
I am very unexperienced with Cisco equipment, so bear with me here.
I'm starting with a CCNA course and have a tiny lab set up with only a Cisco 871w. due to my utter lack of experience, i deleted the contents of the flash storage and no longer have a bootable IOS image. I don't have a spare one I can use xmodem to transfer over, so is there any way to recover an IOS image after the flash has been deleted?
12-16-2019 02:13 PM
if you have an image of the router backup (or you can download from Cisco CCO login) - if you do not have an image, google should help you..(shhhhhhhhhhh cisco hearing).
below guide to upload the image using Xmodem/ TFTP or whichever way suitable.
https://www.cisco.com/c/en/us/support/docs/routers/800-series-routers/15083-recovery-c800.html
12-16-2019 04:39 PM - edited 12-16-2019 04:44 PM
Unfortunately, I'm not able to track down an image for my particular router. I might have just bricked it in my carelessness.
EDIT: I cannot use TFTP as I do not have an ISP connection in my bedroom.
12-17-2019 01:03 AM
Other means of source you need to get the image to fix this issue. TFTP can be local or you can do Xmodem as mentioned in the document.
