Redesigning IP Addressing on live network
durga_suji
I have a task to re-design IP addressing for 2 sites. Have these doubts,
1. At one site we are extending hosts by changing the mask from /24 to /23 for class A ip adress.
What all things i need to keep in mind when i change the mask on the router, then switch, then servers?
Will there be any kind of service disruption?
2. I will need to add a new subnet range at another site and remove the current subnet range after a month. This is also class A. Shall I plan to put the new subnet as secondary IP range or primary IP range or vice versa?
The old subnet will be taken to another site later.
ip address 10.xxx.xx.xx /23 primary
ip address 10.vvv.vv.vv /23 secondary
thanks
Giuseppe Larosa
Hello Srinath,
1) when you change a subnet mask you cause service disruption for sure so you should consider to add the second network in a separate vlan as a /24 (preferred) or as secondary address (if your site cannot support multiple Vlans only in this case)
2) in this case using primary/secondary addresses in the same vlan helps to have a smooth migration.
If using DHCP you need to create a scope for new subnet
Hope to help
Giuseppe
