Redistribute +include-connected
Kevin Dorrell
Level 10
Level 10
Has anyone had any trouble with the include-connected keyword?
12.4(2)T on 2611XM. I was redistributing RIPng into OSPFv3. I tried:
<b>
ipv6 router ospf 100
 redistribute rip RIPng metric 1 include-connected
</b>
That redistributed the router's remote RIP routes, but for some reason it did not redistribute its connected RIPng interfaces. So instead, I did:
<b>
 redistribute connected metric 1
</b>
That worked fine. I am sure that RIPng was running on those connected interfaces, otherwise the rest of my RIP domain would not have had any updates. So why did the include-connected keyword not redistribute them into RIP?
Does anyone know of a bug or limitation in include-connected? I didn't find anything on the bug database.
Kevin Dorrell
Luxembourg
royalblues
Level 10
Level 10
Kevin,
I just tested it and it works fine. have a look
R2
interface Loopback2
no ip address
ipv6 address 4001::1/64
ipv6 rip test enable
interface Loopback1
no ip address
ipv6 address 3001::1/64
ipv6 ospf 100 area 0
interface Serial2/1
no ip address
ipv6 address 2004::1/64
serial restart-delay 0
clock rate 64000
router-id 10.10.10.1
log-adjacency-changes
redistribute rip test metric 1 include-connected
R3
interface Serial2/0
no ip address
ipv6 address 2004::2/64
router-id 10.10.10.2
R3#sh ipv6 route
IPv6 Routing Table - 8 entries
Codes: C - Connected, L - Local, S - Static, R - RIP, B - BGP
U - Per-user Static route, M - MIPv6
I1 - ISIS L1, I2 - ISIS L2, IA - ISIS interarea, IS - ISIS summary
O - OSPF intra, OI - OSPF inter, OE1 - OSPF ext 1, OE2 - OSPF ext 2
ON1 - OSPF NSSA ext 1, ON2 - OSPF NSSA ext 2
D - EIGRP, EX - EIGRP external
C 2004::/64 [0/0]
via ::, Serial2/0
L 2004::2/128 [0/0]
via ::, Serial2/0
O 3001::1/128 [110/64]
via FE80::C001:16FF:FE3C:0, Serial2/0
OE2 4001::/64 [110/1]
L FF00::/8 [0/0]
I can see the loopback being redistributed beacuse of the include connected keyword. Removing it does not redistribute it into ospf
Did the test on 3725 Adavnce IP services image.
Narayan
Thank you Narayan, that's really helpful. I wonder what is going on in my setup then. I shall have to do some more testing. There are one or two differences, but none that should make any difference to the end result. What do you think?
1. I was redistributing both ways, each IGP with its own include-connected. (There was no overlap between the two domains, and all the interfaces were in one or the other IGP.) I don't think the connected were being redistributed in either direction.
2. I had initially tried a metric of 0 each way, which is allowed but was not in my answer book. Puzzled! However, changing to 1 seemed to make no difference.
3. On the OSPF side I was redistributing into an NSSA.
4. The RIPng connected networks that did not get redistributed into OSPF were an Ethernet and a FR point-to-point. I shall try loopbacks on both sides when I get home this evening and see how they behave.
The really strange thing is that I could swear I had full connectivity when I originally configured it on Sunday. I gotta do some more testing until I understand it.
Thanks again.
Kevin Dorrell
Luxembourg
Narayan,
I investigated the problem yesterday evening and found I could not reproduce it. However, I did identify another problem, and I wonder if I got confused.
The problem I identified was concerned with the redistribution metric 0, which seems to be an undocumented feature. From OSPF to RIP, if you specify the metric as zero, then the redistribution metric is the OSPF path cost. That is not so useful because most OSPF path costs come out as more than 15. That is why I was getting some routes redistributed and not others. What puzzles me is how I thought it was the connected routes that were not being redistributed, whereas it was actually the more remote routes that were missing.
Thanks again for trying the include-connected. It gave me the impetus to try it again and investigate what was really going on.
Kevin Dorrell
Luxembourg
Kevin,
Now you have got me confused. I thought RIP does not understand a metric of 0 (and no seed metric) and hence it becomes mandatory to specify the metric while redistributing into RIP.
If Zero is specified, RIP should have treated them anyway as infinite metric (>15)
I think i need to lab it up again to confirm the behavior :-)
Narayan
