redistribute
korbenda11as
this command " redistribute static metric 20 metric-type 1 subnets route-map static-filter" is under our ospf command what does this mean?
6 Replies 6
pkhatri
Level 11
Level 11
It means that static routes configured on the router will be advertised via OSPF as type-1 externals with a metric of 20. THe routes will be passed through the static-filter route-map which will determine which routes get injected and whether or not to give them specific attributes such as metrics.
Paresh.
PS> Pls do remember to rate posts.
Hi Paresh, thanks in responding, appreciate that. Do you know of a link where I can read more about this topic?
I already rate the posts for you.
What particular feature are you after more information on ? Is it redistribution in general ?
Paresh
Yes probably, or anything related to the command which I have in question.
Check this link out. It will give you all necessary information about the OSPF:
http://www.cisco.com/en/US/tech/tk365/technologies_white_paper09186a0080094e9e.shtml
A whole OSPF Stuff:
http://www.cisco.com/en/US/tech/tk365/tk480/tsd_technology_support_sub-protocol_home.html
HTH,Please rate if it does.
-amit singh
