Redistributing from OSPFv3 into EIGRP with a distribute-list
ST Green
I was working on a lab to redistribute routes from OSPFv3 into EIGRP.
First part of the lab required redistributing all OSPFv3 IPv4 routes into EIGRP.  The commands below worked.
router eigrp CISCO
   address-family ipv4 unicast autonomous-system 100
      topology base
         redistribute ospfv3 10 metric 1500 1 255 100 1500
Second part of the lab required filtering the redistributed OSPFv3 routes.  Only the following routes should be redistributed:
172.16.11.0/30
172.16.12.0/24
172.16.41.0/24
172.16.42.0/24
172.16.43.0/24
172.16.44.0/24
192.168.11.0/24
The following routes should be filtered out/NOT redistributed into EIGRP.
10.10.41.0/24
10.10.42.0/24
10.10.43.0/24
10.10.44.0/24
The following config did not work properly.  EIGRP routers still learned 10.10.x.x routes that had been redistributed from OSPFv3.
access-list 1 permit 172.16.11.0/30
access-list 1 permit 172.16.12.0/24
access-list 1 permit 172.16.41.0/24
access-list 1 permit 172.16.42.0/24
access-list 1 permit 172.16.43.0/24
access-list 1 permit 172.16.44.0/24
access-list 1 permit 192.168.11.0/24
router eigrp CISCO
      topology base
         distribute-list 1 out ospf 10
But when I used this config, it worked fine:
router eigrp CISCO
      topology base
         distribute-list 1 out Ethernet0/0
Ethernet0/0 is the interface the ASBR used to connect to its EIGRP peer.
Just wondering why using distribute list on all ospf 10 routes did not work.  Any thoughts?
Is it because I did not use ospfv3 10?
There was no option to use ospfv3 10.  There's no ospfv3 keyword when I ran the redistribute command in the EIGRP topology config level.
Hello
I would expect you need to enable ipv6 routing first to obtain that option OSPFv3 and then you could filter your redistribution in conjunction with a route-map that is then calling either an access/prefilx-list,
Kind Regards
Paul
M02@rt37
Hello @ST Green
distribute-list out command is used to filter routes being advertise out of EIGRP to its neighbors...so with this command distribute-list 1 out ospf 10  you’re not redistribute EIGRP into OSPF.
Best regards
