SD-WAN BFD hardware vs software mode.
njccnp
In the SD-WAN documentation, it says "To change the BFD session modes between software mode and hardware mode, you need to remove all existing BFD configuration and reconfigure it." This seems to be the only mention in the documentation of these modes. Is there a description anywhere of these modes, or a discussion of how to configure them?
Enes Simnica
Level 5
Level 5
The software and hardware BFD modes refer to whether BFD runs on the CPU or is offloaded to hardware for better performance. There’s no command to manually switch modes. And thats why it’s handled automatically based on the device, features in use, and config.
Unfortunately  to change the mode, you’ll need to remove the existing BFD config and reapply it. That’s why the docs mention deleting and reconfiguring/. Cisco doesn’t provide detailed documentation on this. Meaning/ it’s mostly platform dependent.
So there is no command like: bfd mode hardware or mode software LOOOL
Also check these:///
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/command/iosxe/qualified-cli-command-reference-guide/m-bfd-commands.html
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/ha-scaling/ios-xe-17/high-availability-book-xe/m-high-availability-and-scaling.html
-Enes
more Cisco?!
more Gym?!
If this post solved your problem, kindly mark it as Accepted Solution. Much appreciated!
Cedge support hardware bfd' I dont think vedge support it.
To change mode from software to hardware use
Sdwan
 Bfd
  Hardware-offload
MHM
