Redistributing OSPF in to RIPng ?
lowfell
Level 3
Level 3
In the attached diagram we have two distribution switches & Router 4 running Ripng between them.
Router 4 is also part of an OSPF network.
Now, I know I have to redistribute Ripng into the OSPF process of router 4
Do i not have to add some form of OSPF distribution in to the router 4 Ripng process & the two distribution switches?
im not actively doing the lab but looking at the config in place I would think it goes under the rip if your redistributing ospf into it like belwo
     (config )ipv6 router rip RIP_ZONE
(config-rtr) redistribute ospf 6 metric 5 include-connected
7 Replies 7
Mark Malone
I don't see rip on the diag , but you would need mutual redistribution between eigrp and ospf process on R4
you may end up with a default route from nssa into eigrp , where the actual rip configured
Ripng is in the middle diagram labelled Ipv6 Topology. Ripng RIP_ZONE
Do R4 & the two distribution switches need an OSPF redistribution command & if so what is the command?
sorry didn't scroll down :) thought was one screenshot
this is already raised in multiple forums , I see another post in the learning network too exact same topology and questions
http://www.techexams.net/forums/ccnp/54303-ipv6-route-redistribution.html
Ok, Mark. According to that post he needs to add this to R4
(config-router)redistribute ospf 6 metric 5 include-connected
Where about's in the config is this added?
version 12.4
hostname R4
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ipv6 unicast-routing
ipv6 cef
archive
log config
hidekeys
interface Tunnel34
no ip address
ipv6 address 2026::34:2/122
ipv6 ospf 6 area 34
tunnel source 10.1.1.10
tunnel destination 10.1.1.9
interface FastEthernet0/0
ip address 10.1.4.5 255.255.255.252
speed 100
full-duplex
ipv6 address 2026::2:1/122
ipv6 rip RIP_ZONE enable
interface Serial0/0
no ip address
encapsulation frame-relay IETF
clock rate 2000000
frame-relay lmi-type ansi
interface Serial0/0.34 point-to-point
ip address 10.1.1.10 255.255.255.252
snmp trap link-status
frame-relay interface-dlci 403
interface FastEthernet0/1
ip address 10.1.4.9 255.255.255.252
speed 100
full-duplex
interface Serial0/1
no ip address
shutdown
clock rate 2000000
router eigrp 10
redistribute ospf 1 route-map OSPF->EIGRP
network 10.1.4.4 0.0.0.3
network 10.1.4.8 0.0.0.3
default-metric 2000 2000 255 1 1500
no auto-summary
router ospf 1
log-adjacency-changes
area 34 nssa
redistribute eigrp 10 subnets route-map EIGRP->OSPF
network 10.1.1.8 0.0.0.3 area 34
ip forward-protocol nd
no ip http server
no ip http secure-server
access-list 10 permit 10.2.1.0 0.0.0.255
access-list 10 permit 10.2.2.0 0.0.0.255
access-list 10 permit 10.1.4.4 0.0.0.3
access-list 10 permit 10.1.4.8 0.0.0.3
access-list 10 permit 192.168.1.128 0.0.0.31
access-list 10 permit 10.2.4.12 0.0.0.3
access-list 20 permit 0.0.0.0
access-list 20 permit 10.1.1.0 0.0.0.3
access-list 20 permit 10.1.1.4 0.0.0.3
access-list 20 permit 10.1.1.8 0.0.0.3
ipv6 router ospf 6
redistribute rip RIP_ZONE include-connected
route-map EIGRP->OSPF permit 10
match ip address 10
route-map OSPF->EIGRP permit 10
match ip address 20
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
end
Thanks for your help Mark. Greatly appreciated.
no probs good luck with the labbing
