Redistributing Routes between OSPF and EIGRP
drmrkam01
Hi there.
We have in our network cisco router and alcatel switchs.
before in cisco router run Eigrp with 2mb link and use static redistributing.
now we use Alcatel switch and OSPF with 100mb but still all route goes though 2mb link.
which kind of priority can set in cisco router that use only ospf for routing.
please help.
10 Replies 10
Seb Rupik
Hi there,
You can change the administrative distance under the router process:
router ospf 1
distance 80
Should effect all the routes learnt via the OSPF process.
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_ospf/command/iro-cr-book/ospf-a1.html#wp8791238050
cheers,
Seb.
thanks but still not use ospf 100mb link.
Is OSPF configured on the Cisco router, has it formed an adjacency with the alactel switch?
Can you provide the config for the alactel switch and cisco router?
cheers,
Seb.
yes its confured and have adjacency with alcatel.
Alcatel switch
-> show ip route
 + = Equal cost multipath routes
 * = BFD Enabled static route
 Total 11 routes
-> write terminal
! Stack Manager :
! Chassis :
system name vxTarget
system daylight savings time disable
! Configuration:
! MULTI-CHASSIS :
! VLAN :
vlan 1 enable name "VLAN 1"
! VLAN SL:
! IP :
ip service all
ip interface "mgmt" address 172.16.1.110 mask 255.255.255.252 vlan 1 ifindex 1
! IPX :
! IPMS :
! AAA :
aaa authentication default "local"
! PARTM :
! AVLAN :
! 802.1x :
! KERBEROS :
! QOS :
! Policy manager :
! Session manager :
! SNMP :
! RIP :
! OSPF :
ip load ospf
ip ospf area 0.0.0.0
ip ospf interface "mgmt"
ip ospf interface "mgmt" area 0.0.0.0
ip ospf interface "mgmt" status enable
ip ospf status enable
! BFD-STD :
! IPv6 :
! IPSec :
! IP multicast :
ip static-route 0.0.0.0/0 gateway 172.16.1.109 metric 1
! RIPng :
! OSPF3 :
! BGP :
! ISIS :
! Health monitor :
! Interface :
! Netsec :
! Link Aggregate :
! Udld :
! Port Mapping :
! VLAN AGG:
! 802.1Q :
! Spanning tree :
bridge mode 1x1
! Bridging :
! Bridging :
! Port mirroring :
! UDP Relay :
! Server load balance :
! System service :
swlog console level info
! SSH :
! VRRP :
! Web :
! AMAP :
! Lan  Power :
! NTP :
! RDP :
! VLAN STACKING:
! Ethernet-OAM :
! EFM-OAM :
! ERP :
! SAA :
! Loopback-detection :
! DHCP Server :
! WCCP :
! LLDP :
! Link-fault-propagation :
! DHL :
! PPPOE-IA :
! TESTOAM :
! DA-UNP :
! SIP Snooping :
! DHCPv6 :
! Stack Split-Protection Helper :
Routes from 172.16.1.106
  Dest Address      Subnet Mask       Gateway Addr      Age       Protocol
  0.0.0.0           0.0.0.0             172.16.1.105         2d 4h  NETMGMT
  127.0.0.1         255.255.255.255     127.0.0.1            2d 5h  LOCAL
  172.16.0.31       255.255.255.255     172.16.1.105      00:07:07  OSPF
  172.16.1.64       255.255.255.252     172.16.1.105      00:07:07  OSPF
  172.16.1.72       255.255.255.252     172.16.1.105      00:07:07  OSPF
  172.16.1.104      255.255.255.252     172.16.1.106         2d 5h  LOCAL
  172.16.1.140      255.255.255.252     172.16.1.105      00:07:07  OSPF
  172.16.1.144      255.255.255.252     172.16.1.105      00:07:07  OSPF
  192.168.3.0       255.255.255.0       172.16.1.105      00:07:07  OSPF
  192.168.72.0      255.255.255.0       192.168.72.200       2d 2h  LOCAL
  192.168.75.0      255.255.255.0       172.16.1.105      00:07:07  OSPF
Hi there,
Its work so far good ,only one problem.
when i use redistribute with subnets then it's start to use EIGRP link.
and this is one way redistribute.
It's possible to change the priority for redistribute route to they can use one OSPF link.
or any other solution
i have static redistributing eigrp maybe i need to use
router eigrp 1
 redistribute ospf 1 metric 1500 20000 255 1 1500
router ospf 1
 redistribute eigrp 1 metric 100 subnets
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
By default, EIGRP has a better AD than OSPF.
I see your later post, where you mutually redistribute between EIGRP and OSPF, but what routing protocols are running on the router on your diagram?  Also, the 2 Mbps link is shown as directly connected to that router, correct?
Yes its directly connected to cisco router and in cisco router is configured EIGRP and OSPF,
Alcatel only OSPF.below is cisco router runing config.
controller E1 0/0
channel-group 1 timeslots 1-31
controller E1 0/1
controller E1 1/0
controller E1 1/1
interface Loopback0
ip address 172.16.0.31 255.255.255.255
no ip unreachables
no ip proxy-arp
interface FastEthernet0/0
ip address 192.168.3.40 255.255.255.0 secondary
ip address 192.168.3.1 255.255.255.0 secondary
ip address 192.168.75.2 255.255.255.0 secondary
ip address 192.168.75.40 255.255.255.0
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
interface Serial0/0:1
description Link To BOX-158
ip address 172.16.1.146 255.255.255.252
no ip unreachables
no ip proxy-arp
interface FastEthernet0/1
description Link to Alcatel-Lucent
ip address 172.16.1.105 255.255.255.252
no ip unreachables
no ip proxy-arp
delay 120
duplex auto
speed auto
interface Serial0/1:1
ip address 172.16.1.66 255.255.255.252
no ip unreachables
no ip proxy-arp
interface Serial1/0:1
description Link to BOX-134
ip address 172.16.1.141 255.255.255.252
no ip unreachables
no ip proxy-arp
interface Serial1/1:1
description Link To DZK-R2
ip address 172.16.1.73 255.255.255.252
no ip unreachables
no ip proxy-arp
router eigrp 65000
redistribute static
network 172.16.0.31 0.0.0.0
network 172.16.1.64 0.0.0.3
network 172.16.1.72 0.0.0.3
network 172.16.1.104 0.0.0.3
network 172.16.1.140 0.0.0.3
network 172.16.1.144 0.0.0.3
network 192.168.3.0
network 192.168.75.0
no auto-summary
router ospf 1
network 0.0.0.0 255.255.255.255 area 0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.75.6
ip tacacs source-interface Loopback0
no ip http server
logging source-interface Loopback0
logging 192.168.210.200
logging 192.168.1.12
access-list 1 permit 192.168.1.85
access-list 1 permit 192.168.1.12
access-list 1 permit 192.168.210.200
access-list 1 permit 172.16.1.12
access-list 1 deny any log
tacacs-server host 192.168.1.11 key 7 011F141048340D0A38
tacacs-server directed-request
snmp-server community wkhtudfgs RO 1
snmp-server trap-source Loopback0
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
dial-peer cor custom
banner motd ^C
This is a private system!!! All connection attempts are
logged and monitored. All unauthorized connection
attempts will be investigated and handed over
to the proper authorities.
^C
line con 0
exec-timeout 30 0
logging synchronous
line aux 0
exec-timeout 30 0
logging synchronous
transport input telnet
line vty 0 4
exec-timeout 30 0
logging synchronous
ntp clock-period 17178949
ntp server 172.16.0.14
end
Disclaimer
Posting
If I'm reading your config correctly, this router shows no redistribution between EIGRP and OSPF, and shows all interfaces incorporated in both.  Again, by default EIGRP has a better AD, the EIGRP path would be the preferred.
Try Seb's suggestion.
So i need to configur these commad in cisco router i think.?
router eigrp 1
router ospf 1
