Redistributing Static Route in to BGP
GillieLucent
Hi all,
I am having the following doubt in Redistributing static routes into BGP .
Consider eBGP between R2 and R3.
Configurations are :
R2 configs :
hostname R2
ip route 150.1.1.0/24 10.1.1.20
router bgp 100
redistribute static
neighbor 40.1.1.30 remote-as 200
R3 configs :
router bgp 200
neighbor 40.1.1.20 remote-as 100
When I do 'show ip bgp' in R3, it shows as below :
*> 150.1.1.0/24 40.1.1.20 100 100 ?
My doubt is why it is showing the route as incomplete (?), Won't it be 'e' because it got that route from ebgp neighbor R2. Correct me if I am wrong.
Vijaybabu
7 Replies 7
mheusinger
Level 10
Level 10
the ? refers to the origin code, which can have 3 values:
i - IGP, i.e. a network statement under router bgp was configured
e - EGP, this is NOT eBGP, but a previous protocol (Exterior Gateway Protocol) not in use today
? - incomplete, i.e. it was included into the BGP table through redistribution
This means everything is fine and as it should be in your case.
Hope this helps! Please rate all posts.
regards, Martin
Hi Martin,
Thanks for explanation.
what will be the case if it's learned from eBGP ?
Vijaybabu
the origin code is set by the router originally inserting the network into the BGP table. During this process you can modify the origin code with a route-map.
The origin code does not depend on the way it is learned (iBGP or eBGP). Routes that were sent at least once through an eBGP session can be seen from the fact, that the AS path is not empty. The complete "story" can be seen from "show ip bgp ". There you will get a statement which either tells you "internal" (learned through iBGP) or "external" (learned through eBGP).
Regards, Martin
Hi Martin,
I have one doubt, you said all redistributed routes will come as '?'. But when I redistributed 'connected' routes , it showing as below :
R2 config:
router bgp 100
redistribute connected
R3 config:
router bgp 200
Show ip bgp in R3
Network Next Hop Metric LocPref
Path
*> 10.1.1.0/24 40.1.1.20 100 100 i
* 40.1.1.0/24 40.1.1.20 100 100 i
*> 101.101.101.20/32 40.1.1.20 100 100 i
As you said, it should come as '?'. Correct me if I am wrong .
Vijaybabu
As Martin stated, it should come as '?' when doing redistibuted connected under the BGP process, unless you have a route-map altering the origin.
Can we see a larger portion of the config ?
Here is mine:
Router 1:
router bgp 2
no synchronization
bgp log-neighbor-changes
redistribute static
neighbor 172.25.1.1 remote-as 1
neighbor 172.25.1.1 ebgp-multihop 10
default-information originate
no auto-summary
#sh ip int brief
FastEthernet0/0 192.168.66.1 YES NVRAM up up
Serial0/0 172.25.1.2 YES NVRAM up up
Loopback0 10.40.1.1 YES NVRAM up up
Loopback1 10.45.1.1 YES NVRAM up up
Loopback2 10.50.1.1 YES NVRAM up up
Loopback3 10.55.1.1 YES NVRAM up up
Router 2:
#sh ip bgp
BGP table version is 63, local router ID is 199.21.21.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*> 0.0.0.0 172.25.1.2 0 0 2 ?
*> 10.40.0.0/16 172.25.1.2 0 0 2 ?
*> 10.45.0.0/16 172.25.1.2 0 0 2 ?
*> 10.50.0.0/16 172.25.1.2 0 0 2 ?
*> 10.55.0.0/16 172.25.1.2 0 0 2 ?
*> 10.150.1.0/24 172.25.1.2 0 0 2 ?
Please rate helpful posts.
Hi Edison,
Thanks for your extensive help.
I have one more doubt, how learning routes from any IGP(though it happens only because of redistribution) show as 'i' ? it shud come as '?'. correct me if I am wrong.
Kindly, can you post me samples containing 'i' routes in 'show ip bgp ' output.
Vijaybabu
I believe you are confusing IGP with iBGP.
IGP = EIGRP, OSPF, RIP and the others.
iBGP = Internal BGP, BGP peers sharing the same AS.
Only with iBGP learned routes you will see the 'i'.
