04-05-2005 02:38 AM - edited 03-03-2019 09:12 AM
Good morning,
when I redistribute the static in OSPF,does the process redistribute also the default gateway 0.0.0.0 0.0.0.0 ?
Is there any other command for this?
Any CCO link welcome.
Matteo
Solved! Go to Solution.
04-05-2005 02:47 AM
" The OSPF router does not, by default, generate a default route into the OSPF domain. In order for OSPF to generate a default route, you must use the default-information originate command."
This is an excerpt from:
How OSPF Injects a Default Route into a Normal Area
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a00801ec9f0.shtml
There are more docs on the OSPF support pages:
http://www.cisco.com/en/US/tech/tk365/tk480/tsd_technology_support_sub-protocol_home.html
Mustafa
04-05-2005 02:47 AM
Mustafa
