Redistribution between two EIGRP Autonomous Systems
Andy White
Level 3
Level 3
I will have the possible task of joining our EIGRP network to another one and they are on different AS numbers.  I'm going to use GNS3 to help me plan this, but can you give me some advise on how I can redistribute their EIGRP AS into ours and visa versa?  I have done basic redistribution before with RIP into EIGRP and connected subnets, but nothing this big .
6 Replies 6
cadet alain
do mutual redistribution on one router running both processes:
router eigrp 1
redistribute eigrp 2 metric x x x x x
router eigrp 2
redistribute eigrp 1 metric x x x x x
Alain
you can collect the metric values in interfaces using below command.
Sh interfaces
Is this to get their current metrics?
yes.. You can type show interface and specify the interface you need to know the metric values..
Thanks as always Alain, I will give it a try.
can we use this command
router eigrp 1
redistribute eigrp 2 metric-type 1 subnets
router eigrp 2
redistribute eigrp 1 metric-type 1 subnets.
