Redistribution from Eigrp to OSPF
Vishalhathi
Hi Team,
Please refer attached exhibit topology
here i'm using 2way redistribution between  EIGRP to  OSPF .now i want my source ip 1.1.1.1 and 11.11.11.11 prefer path via S0/1(R2,R3) to reach destination 4.4.4.4 instead of S0/2 (R2 to R4) so is it possible without changing AD or metric ?
as per my understanding it is not possible using PBR because Ex.Eigrp AD = 170 and OSPF AD=110
so if i want to my source ip should prefer path via (R2,R3) that time i have to change only AD so it will travel via that way only.
Kindly suggest on it.
Vishal
Richard Burts
Vishal
If I am understanding correctly you want to control the path that traffic takes based on the source address. You can not change the AD or the metric based on the source address of traffic. The only way that I know to control the path used based on source address is to use PBR.
Rick
Rick
