Redistribution of iBGP and eBGP
luqman_khalid
NW DiagramNW Diagramfrom PC i can ping ISP on loop back 8.8.8.8 via site A, but when i
Shutdown F0/1 of SITE-A , i cannot ping ISP from PCs.
Actually i want to switch traffic to SITE-B , if SITE-A's link is down.
PCs can ping SITE-B ip Address 192.168.1.2 but cannot ping f0/0 of SITE-B.
ISP and SITE-B can learn routes of PCs but cannot ping them,
I think problem is redistribution of ibgp and ebgp.
AS of ISP = 17557
AS of Site-A and B = 65468.
Please help
#bgp
#ibgp
#ebgp
9 Replies 9
balaji.bandi
you posted this problem earlier this morning and then removed the discussion. Your switch LAB-SW was used as a layer 3 switch, is it participating in BGP as well ?
I remember noticing that you missed the below in your iBGP neighbor configuration, try and add this and check if the failover works then:
SITE-A
neighbor 192.168.1.2 next-hop-self
SITE-B
neighbor 192.168.1.1 next-hop-self
In any case, repost the full configs of all four devices (the three routers and the switch.
no BGP is not enabled on L3 switch. next-hop-self didnot work , i have already tried.
not working with next-hop-self
Hello
Using the weight PA wont take any affect when you have ibgp peering also deactivate synchronization, append the following and test again
ISP
router bgp 17557
network 8.8.8.8 mask 255.255.255.255
network 58.181.114.168 mask 255.255.255.252
network 221.120.214.176 mask 255.255.255.252
no redistribute static <-- not required
no neighbor 221.120.214.178 allowas-in <-- not required
Site A
router bgp 65468
neighbor 192.168.1.2 next-hop self
address-family ipv4
no neighbor 192.168.1.2 soft-reconfiguration inbound <-- not required
no neighbor 221.120.214.177 soft-reconfiguration inbound <-- not required
no synchronization
network 192.168.1.0
bgp default local-preference 500
redistribute static
exit
clear ip bgp soft *
Site B
router bgp 65468
neighbor 192.168.1.1 next-hop self
address-family ipv4
no neighbor 58.181.114.77 weight 90  <-- not required
no synchronization
network 192.168.1.0
clear ip bgp soft *
Kind Regards
Paul
no working with this also
I could not even get to 8.8.8.8 from anywhere with announcing the network in BGP on the ISP router, not sure if that was the problem. Either way, my working configs are below:
ISP
router bgp 17557
bgp log-neighbor-changes
neighbor 58.181.114.78 remote-as 65468
neighbor 221.120.214.178 remote-as 65468
address-family ipv4
redistribute static
neighbor 58.181.114.78 activate
neighbor 58.181.114.78 weight 100
neighbor 58.181.114.78 soft-reconfiguration inbound
neighbor 221.120.214.178 activate
neighbor 221.120.214.178 weight 200
neighbor 221.120.214.178 soft-reconfiguration inbound
exit-address-family
SITE-A
router bgp 65468
neighbor 192.168.1.2 remote-as 65468
neighbor 221.120.214.177 remote-as 17557
address-family ipv4
network 221.120.24.192 mask 255.255.255.252
network 221.120.24.196 mask 255.255.255.252
network 221.120.212.64 mask 255.255.255.252
neighbor 192.168.1.2 activate
neighbor 221.120.214.177 activate
exit-address-family
SITE-B
router bgp 65468
neighbor 58.181.114.77 remote-as 17557
neighbor 192.168.1.1 remote-as 65468
address-family ipv4
neighbor 58.181.114.77 activate
neighbor 192.168.1.1 activate
neighbor 192.168.1.1 soft-reconfiguration inbound
exit-address-family
The config i posted above should work, Probably decrease the BGP timers and test again
all rtrs
router bgp xxx
timers bgp 3 10
exit
clear ip bgp *
Kind Regards
Paul
