09-14-2011 05:32 AM - edited 03-04-2019 01:36 PM
Hi ,
I want to know how can I achive redundancy between two links from same ISP .
I m using bgp here , we can consider both senario where both links will be having same AS no and diffrent AS nos .
Thanks for reply
09-14-2011 05:40 AM
If you receive same routes from both ISPs or at least the default route you can use some bgp attribute to let your router prefer one link over the other and the other one can be used as fallback or back pun
You Can use any if the bellow in the inbound direction withna route map
Local preference
Bgp wight
See the bellow link you may find a useful example
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a00800945bf.shtml#conf2
Hope this help
If helpful rate
09-20-2011 12:44 AM
Hi marwanshawi ,
Thanks for the reply , but here I want to know how can I achive redundancy between two links from same ISP having same AS no .
09-20-2011 12:57 AM
If you want redundancy for the BGP TCP session not going down when 1 link fails then:
do your eBGP peering with loopbacks on both sides, don't forget to use eBGP-multihop as by default eBGP TTL=1.
Here is an example: suppose R1 is your router and R2 the ISP and you're connected with s1/0 and s1/1
R1:
int lo0
ip add 1.1.1.1 255.255.255.0
int s1/0
ip add 10.1.1.1 255.255.255.0
int s1/1
ip add 10.2.2.1 255.255.255.0
ip route 1.1.1.0 255.255.255.0 10.1.1.2
ip route 1.1.1.0 255.255.255.0 10.2.2.2
router bgp 100
neigh 2.2.2.2 remote-as 200
neigh 2.2.2.2 update-source lo0
neigh 2.2.2.2 ebgp-multihop 2
R2:
int lo0
ip add 2.2.2.2 255.255.255.0
int s1/0
ip add 10.1.1.2 255.255.255.0
int s1/1
ip add 10.2.2.2 255.255.255.0
ip route 2.2.2.0 255.255.255.0 10.1.1.1
ip route 2.2.2.0 255.255.255.0 10.2.2.1
router bgp 200
neigh 1.1.1.1 remote-as 100
neigh 1.1.1.1 update-source lo0
neigh 1.1.1.1 ebgp-multihop 2
Regards.
Alain
