ā04-04-2019 11:35 PM
All of the routers are running EIGRP as routing protocol. my problem is when MPLS ISP2 is having an intermittent connection my gateway is also not stable because every time MPLS ISP2 goes UP EIGRP choose it because it has better metrics. what I want is to force traffic and stay on MPLS ISP1 when MPLS ISP2 down on the first time when intermittent connection.
ā04-05-2019 01:26 AM
- It will be very difficult for network devices to decide on that 'proposal'. Indeed the MPLS ISP2 can go down, but the following intermittent-statuses are undefined in terms of decision-making by intelligent protocols, unless this mechanism could be encoded in policies. Far better then to resolve the intermittent issues.
M.
ā04-05-2019 04:48 AM
ā04-05-2019 04:54 AM
You can use interface dampening for that kind of scenario. Here is the configuration guide for this feature:
https://www.cisco.com/c/en/us/td/docs/ios/12_0s/feature/guide/s_ipevdp.html
It allows you to make sure the interface is stable enough before allowing traffic to pass through it.
ā04-07-2019 10:27 AM
HI,
You can use the EEM scripting. or and as per my knowledge, IP Event Dampening will not resolve your issue because eigrp is running over the tunnel interface but your physical link is flapping.
