Redundancy on routers and switches
vinodmehrag
I am using 2 2960 switches and 4 1840 routers.
I want to know how to achive redundancy on routers and switches for my design.
My objective is as follows:
I need to run bgp on routers
If linkA fails, traffic flow has to be throgh linkB and linkD
If linkC fails, traffic flow has to be throgh linkA and linkE
If linkC and linkE fails, traffic flow has to be throgh linkB and linkD
Any help is highly appreciated.
Vinod
milan.kulik
Level 10
Level 10
ad If link A fails, traffic flow has to be throgh linkB and linkD)
This can be done by HSRP running between R1 and R2 on the LAN side with WAN line tracking
ad If linkC fails, traffic flow has to be throgh linkA and linkE)
You'd need an SVI L3 interface configured on R1 with C and E switched (L2) interfaces belonging to the VLAN assigned to the SVI.
C and E would be used by the LAN devices depending on their place in the L2 topology. One of them might be blocked by STP, in that case tuning STP might make E blocked as long as C is Up.
(And similar configuration on R2.) With HSRP running over the SVIs as mentioned above, this would work. As 1840s are offering integrated switch, this might be possible. (But I have never configured that personally.)
If linkC and linkE fails, traffic flow has to be throgh linkB and linkD)
Yes, the design proposed above would fulfil this, too.
HTH,
Milan
