Redundant Internet connections on 1812 router
jeremy.lebeau
I am trying to set up a 1812 router with 2 internet connections. One is a cable connection with DHCP and the other is DSL with static IP addresses. Neither ISP supports BGP for me.
I have looked at this link (http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a00808d2b72.shtml) but I'm still having some trouble figuring out what to do with the set up in my situation.
Any help on this would be appreciated.
5 Replies 5
paolo bevilacqua
Hi, you can start with a simpler configuration:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080950834.shtml
Then when is working you add OER, firewall, etc, as needed.
Thanks. That link makes a little more sense. The dialer interface has me a little off, but hopefully I can do something with that.
If you don't have PPP, don't configure dialer. You might have to configure a BVI instead.
This is what I have. Am I following this correctly?
version 12.4
hostname 1812Router
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
resource policy
ip cef
interface FastEthernet0
ip address 1.2.3.4 255.255.255.248
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet1
ip address dhcp
ip nat outside
duplex auto
speed auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
description LAN Interface
ip address 192.168.3.254 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map dhcp-nat interface FastEthernet1 overload
ip nat inside source route-map fixed-nat interface FastEthernet0 overload
ip nat inside source static tcp 192.168.3.175 80 1.2.3.4 80 route-map fixed-nat extendable
ip nat inside source static tcp 192.168.3.175 443 1.2.3.4 443 route-map fixed-nat extendable
ip nat inside source static tcp 192.168.3.203 80 1.2.3.5 80 route-map fixed-nat extendable
ip nat inside source static tcp 192.168.3.203 443 1.2.3.5 443 route-map fixed-nat extendable
ip nat inside source static tcp 192.168.3.1 25 1.2.3.6 25 route-map fixed-nat extendable
ip nat inside source static tcp 192.168.3.1 80 1.2.3.6 80 route-map fixed-nat extendable
ip nat inside source static tcp 192.168.3.1 443 1.2.3.6 443 route-map fixed-nat extendable
ip nat inside source static tcp 192.168.3.205 20 1.2.3.7 20 route-map fixed-nat extendable
ip nat inside source static tcp 192.168.3.205 21 1.2.3.7 21 route-map fixed-nat extendable
ip nat inside source static tcp 192.168.3.202 80 1.2.3.7 80 route-map fixed-nat extendable
ip nat inside source static tcp 192.168.3.202 443 1.2.3.7 443 route-map fixed-nat extendable
ip nat inside source static tcp 192.168.3.201 80 1.2.3.8 80 route-map fixed-nat extendable
ip nat inside source static tcp 192.168.3.201 443 1.2.3.8 443 route-map fixed-nat extendable
access-list 110 permit ip 192.168.3.0 0.0.0.255 any
no cdp run
route-map fixed-nat permit 10
match ip address 110
match interface FastEthernet0
route-map dhcp-nat permit 10
match interface FastEthernet1
Just add:
ip route 0.0.0.0 0.0.0.0
and the static NAT should not need to reference route-map. Actually not even the dynamic nat do, but cisco says otherwise in their examples.
