Reg:1841 router help
dhanikonda
Dear experts,
iam facing a big problem that is
Access Rule1: 172.16.0.34 IP should be allowed through LAN.
Access Rule2: Allowed network traffic 172.16.2.100 - 172.16.2. 254
Except the above network range no other traffic should be allowed through our LAN (LAN to WAN).
How can i do this .If any body helps i will be very greatfull to him.
Thanks&Regards
srini
Edison Ortiz
access-list 1 permit ip host 172.16.0.34
access-list 1 permit ip 172.16.2.100 0.0.0.3
access-list 1 permit ip 172.16.2.104 0.0.0.7
access-list 1 permit ip 172.16.2.112 0.0.0.15
access-list 1 permit ip 172.16.2.128 0.0.0.127
HTH,
__
Edison.
Please rate helpful posts
Edison Ortiz
HTH,
__
Edison.
Dear ediortiz,
Thanks u very much ur help and can u explain
what is the 0.0.0.3
iam very thankfull to u.
Srini
Srini...
0.0.0.3 is wildcard mask in the statement.
It implies tat this acl will permit ip's from 172.16.2.100 till 172.16.2.100.3.(4 hosts)
Its a way of allowing a range of IP addresses.
Zero's in the first 3 octet means the source address should match the 172.16.2.100 exactly.
