Reg:2801 ethernet failover and loadbalance
dhanikonda
Dear sir,
iam having 2800 router and i have 2 isps
i have one is airtel and vsnal now i want to terminate these two links on 2800 router and i want to implement isp failover on ethernet and these two links on loadbalance.
plz give me config examples.
srini
Goutam Sanyal
Level 4
Level 4
Dear Srini,
First, please note that this is a public forum, that's why do not mention any ISP's name.
Seconded, yes can go for failover as well as you can loadbalance.
Goutam
Pls rate if its Clarify!!!
royalblues
Level 10
Level 10
Srini,
You would be required to have your own IP address space (from APNIC) to loadbalance between Bharti and VSNL.
You can then configure BGP and receive default route from the ISPs and loadbalance
Have a look at Radware linkproof device which can help you achieve loadbalancing without the need of BGP and APNIC subnets. We have deployed it and it works perfectly.
It is also very easy to configure and use
http://www.radware.com/Products/ApplicationDelivery/LinkProof/default.aspx
Narayan
