Reg:frame-relay multilink
subashmbi
Hi, Iam subash netork engineer, we are facing one problem in our network.we have one multilink frame-relay connection to remote site 16Mbps.
The problem is we pushed 1gb file in these 16mbps link in ISP side is only getting 1mbps in multilink.
in server side is Nic card bandwidth is 1gbps and in our switch (6509)port is 1000mbps.
pls send some solution tips.
nethelper
Level 3
Level 3
you could try and configure frame relay traffic shaping, if you are sure that your multilink frame relay is working end-to-end. I assume you have multilink configured at the other end of the connection as well ? Can you post the configuration of your routers ?
Nethelper
Have you got CEF turned on at both ends ?
Paresh
