route map
The_guroo_2
Level 2
Level 2
hi can someone plz tell me why we use route map and for what purpose and what is filtering??? in routing..thanks in advance
pkhatri
Level 11
Level 11
Route maps are used for a lot of different purposes in IOS. In the context of routing, consider two particular uses of it:
- when redistributing routes from one protocol to another
- when advertising/receiving routes via BGP
Both of the above applications provide advanced filtering capabilities. The traditional method of filtering was via the use of access-lists. This, however, limits you to just matching on the prefix and prefix length. With route-maps, you have the ability to match on things such as metrics, BGP attributes (communities, AS-PATH), outgoing interface, source of the routing update etc. Based on the matches, you can either decide to permit or deny the route.
Additionaly, with a single route-map, you can specify multiple different clauses so that you can apply different actions to different sets of routes.
Hope that helps - pls rate the post if it does.
Paresh
