Reg:multilink
vasuramnet
Dear Sir,
one of my customer is having 3640 router existing 2mb relaince bandwidth now he was planing to take one more 2 mbps link, bouth links having v.35 interface now total bandwidth 4 mbps
is it posibile to take 4mbps on single 10mbps ethernet port.if it is not posibule plz suggest the solution.
vasu
smothuku
Level 7
Level 7
Dear Vasu ,
Please check the below link for multi link configuration over serial interfaces.
In your case you can bundle two serial interfaces with the help of multi link concept.
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00804a40f9.html
satish
bvsnarayana03
Level 5
Level 5
If i understood correctly, u r planning to replace the 2x2Mbps serial links with a single 4Mbps etherdrop. Yes it can be done.
Otherwise the etherchannel option is available to you for bundling the 2 serial links if they are terminated on same device at either end.
