reg:switch
dhanikonda
Dear sir,
The cisco switch model no are 3750 already multimode GBIC is connected and working, I need to confirm whether single mode GBIC would support in the switch.
Other side switch is 2950 and I have to connect single mode GBIC to be connected.
plz conform the module also.
Thanks&Regards
srini
Giuseppe Larosa
Hello Srini,
you can install a Single Mode GBIC on a C3750 to connect to the other switch.
part number
WS-G5486=
1000BASE-LX/LH GBIC transceiver for MMF and SMF, 1300-nm wavelength. SC connector.
see
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/installation/note/78_15299.html
Hope to help
Giuseppe
spremkumar
Level 9
Level 9
As per the datasheet it does supports all kinda modules, you need to be more specific on the switch model you are referring to get a confirmed response on the query.
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_relevant_interfaces_and_modules.html
regds
