Regard command "commit label PostN" in ASR9K
wfqk
Level 5
Level 5
Hi, Regard command "commit label PostN" in ASR9K has two meanings. One is to commit, and second is its label. My question is how to use its second meaning "label PostN"? Thank you
I hope I correctly understand what you are asking.
If you just use 'commit', the resulting commit ID (as shown when you execute the 'show configuration commit list') is just a sequential numeric value. The optional label just allows you to give a name to the commit ID, which makes it easier to identify later on.
So let's say you change the router name from 'Router' to 'Router_Hub':
RP/0/RSP0/CPU0:Router# configure
RP/0/RSP0/CPU0:Router(config)# hostname Router_Hub
RP/0/RSP0/CPU0:Router(config)# commit
and you use just the 'commit' command, the commit ID will look like this:
RP/0/RSP0/CPU0:Router_Hub# show configuration commit list
SNo. Label/ID User Line Client Time Stamp
1 1000000456 user_admin con0_RSPs1_C CLI 17:11:27 UTC Fri Dec 16 2016
If instead you specify a label:
RP/0/RSP0/CPU0:Router(config)# commit label PostN
the commit ID will reflect that name:
1 PostN user_admin con0_RSPs1_C CLI 17:11:27 UTC Fri Dec 16 2016
Great! Thank you
