12-15-2016 04:16 AM - edited 03-05-2019 07:41 AM
We have been given /29 subnet by the isp. Can it be divided into still smaller subnets?
Mahesh
12-15-2016 06:32 AM
As always: It depends ...
12-16-2016 01:49 AM
This is the only subnet given by isp. one more thing, can i use this public ip block given by ISP to both WAN interface and two different internal networks?
12-16-2016 01:56 AM
When this network is configured on the WAN-side of your router/firewall. You can only use it there. But addresses of that /29 can be used with NAT to point to any internal system. That could be in different internal networks.
12-16-2016 01:52 AM
And to add to 2):
You would reduce you valuable public address-space from five usable addresses to two addresses. If your plan is to separate servers, you could also put them all into one subnet and do the separation on the switch-level with port-ACLs, private VLANs or private VLAN Edge.
