Regarding null route
ncnaveen_arasu
                   Hi.
Just imagine we have three routers A,B and C
A is connected to both B and C.
If we define a blackhole route in A as
ip route 0.0.0.0 0.0.0.0 null0.
Wether it generates a default routes to its downstream router sucha a B and C.
Plelase clarify.
14 Replies 14
John Blakley
Without labbing this up, I would say that it would generate the route, but once b and c receive and try to use it, router A will blackhole the traffic. Again though, I would have to lab this up....
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
mfurnival
Level 4
Level 4
You haven't said what routing protocols (if any) you are using betweeen A, B and C.
Jon Marshall
Naveen
Not possible to say with the information you have provided.
A static route on it's own is not sent to other routers. If you were redistributing statics into your IGP or using "default-information originate" under your IGP then yes it should be sent to the other routers.
But if you were just adding a static and not running a routing protocol then no it won't.
Jon
mfurnival
Level 4
Level 4
Just tried this in GNS3 and BGP DOES advertise the route:
R1:
router bgp 1
no synchronization
bgp log-neighbor-changes
redistribute connected
redistribute static
neighbor 192.168.1.2 remote-as 1
neighbor 192.168.1.2 soft-reconfiguration inbound
no auto-summary
ip route 0.0.0.0 0.0.0.0 Null0
R2:
R2#sh ip ro 0.0.0.0
Routing entry for 0.0.0.0/0, supernet
  Known via "bgp 1", distance 200, metric 0, candidate default path, type internal
  Last update from 192.168.1.1 00:02:26 ago
  Routing Descriptor Blocks:
  * 192.168.1.1, from 192.168.1.1, 00:02:26 ago
      Route metric is 0, traffic share count is 1
      AS Hops 0
That's because you have redistribute static under your BGP config.
If you just configure a static and don't redistribute or use "default-information originate" it shouldn't.
Jon
Jon,
Yes - all that is true.
I thought the nature of the question was whether a route pointing to null0 would be advertised (rather than a route pointing to a next-hop or an interface) - regardless of how that advertisement took place.
Ahh i understand.
A static route is no different whether it points to a next hop IP or an interface and null0 is an interface in this respect (although it behaves differently in other respects).
So there is no reason why it wouldn't be advertised unless you aren't redistributing/default-information etc.
Jon
Correct me if I'm wrong though - I still haven't labbed this up
Regardless of if it's advertised out, the "unknown" route will be sent to the advertising router, but if that route is also unknown to it, then it will just drop traffic. So, in reality, the only way this configuration would make any sense is if the router that's advertising this null default route has visibility to all subnets either by full bgp table or something like that.
HTH,
John
Hi John
Not sure i am following but maybe i misunderstood the original question.
I thought the question was asking if you configured a static default route on router A would it be advertised to B and C. To which,, as far as i know, it won't unless -
a) you are running a routing protocol between A, B and C
and
b) you are redistrbuting that static into the IGP or using "default-information originate"
i'm not sure what you mean when you say -
ie. if it is not advertised out then there is no advertising router.
Jon
Sorry Jon, I may be confusing the issue.
I was assuming that they were using a routing protocol to distribute a default route. What I meant was that even if that default route was distributed, when the advertising router really needed to use the default, it wouldn't be able to because that traffic would be blackholed. For example, I finally labbed this up:
R1 ---- R2 --- R3
R1 has a loopback of 1.1.1.1
R1, 2, and 3 are running ospf, but R1 is not advertising the loopback.
There is a static route for 0/0 on R2 pointing to R1.
From R3:
R3(config)#do ping 1.1.1.1
Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
If I change the default route on R2 to 0/0 null 0, R3 will no longer be able to get to R1's loopback:
R2(config)#no ip route 0.0.0.0 0.0.0.0 192.168.12.1
R2(config)#ip route 0.0.0.0 0.0.0.0 null0
R2(config)#do sh ip route
S*   0.0.0.0/0 is directly connected, Null0
U.U.U
That's what I meant by it wouldn't matter if the receiving router had the default route. Once it went to use it, the advertising router would drop the traffic. I guess my other question is why would you want to advertise a nulled default route anyway?
HTH,
John
John
I see what you mean.
In terms of when you would to want to advertise it you pretty much covered it in your previous post. A router with a static route pointing to null0 and then advertising that would always be assumed to have full routing information ie. in your example R2 would actually have a route to R1's loopback.
So any traffic ending up at the router would be dropped if that router does not have a more specific route for it. It is a way to make sure you are not forwarding any packets for which you don't have a route for.
Jon
Thanks for the clarification. I thought I was losing it from the flu meds I'm on
HTH,
John
ncnaveen_arasu
HI Jon,
Thanks for the info.. and i do rate all posts and all were very usefull for me to get the knowledge from youe end.
Thanks for sharing your knowledge and clearing my many doubts.
Naveen
Apologies, you do rate posts as you say.
I don't know why i thought you didn't, my mistake.
Jon
