regarding SYN-FIN floods
saimbt
One of our routers was detected being vulnerable to SYN-FIN flood attack. Will this be cured by disabling "ip http server" on the router?
-Sai.
Tsasbrink
not realy as it will activly "fin"the syn.
You should use an accesslist to the management destination to prevent this.
is there any specific ports I should block??
i did not understand ur message.
-Sai.
yep to the vunrable device you should block evry port witch is not used.
deny ip any
in front of this statement you can put the permits (telnett example) witch are used for management.
permit tcp any eq 23
end the acl by permitting all allowed traffic through.
But it would be highly recommended to use a device / software witch is not vunrable as these filtest do cost performance.
What kind of device are we talking about in what situation ?
