Reload due to a software-forced crash
David Lin
Hi, I got "Reload due to a software-forced crash" problem during the boot of one AS5350 earlier. Then I reloaded the a boot image to bootflash by xmodem. Now I can login the router by boot mode. But it replied "Bad device info block" when I show either flash or bootflash. So I can't load any new image to the flash.
Can anyone guide me how to solve this problem? Thank you.
Router(boot)#show ver
IOS (tm) 5350 Software (C5350-BOOT-M), Version 12.3(15b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Thu 25-Aug-05 15:59 by ssearch
Image text-base: 0x60008AFC, data-base: 0x60480000
ROM: System Bootstrap, Version 12.2(1r)1, RELEASE SOFTWARE (fc1)
Router uptime is 57 minutes
System returned to ROM by error - a Software forced crash, PC 0x60161210 at 10:34:30 EST Fri Oct 31 2008
System image file is "bootflash:c5350-boot-mz.123-15b.bin"
Backplane HW Revision 1.0, Flash Type 5V
2 FastEthernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
512K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
16384K bytes of processor board Boot flash (Read/Write)
Boot output:
TAC Support: http://www.cisco.com/cgi-bin/ibld/view.pl?i=support
Copyright (c) 2001 by cisco Systems, Inc.
bus error while trying to access flash - addr = 0xb0000000
cannot read flash info
Unsupported system flash simms detected
Replace flash simms
Both flash simms must be of the same type
AS5350 platform with 524288 Kbytes of main memory
getdevnum warning: device "flash" has size of zero
open: read error...requested 0x4 bytes, got 0x0
trouble reading device magic number
boot: cannot open "flash:"
boot: cannot determine first file name on device "flash:"
Replace flash simms
Self decompressing the image : #################### [OK]
8 Replies 8
Giuseppe Larosa
Hello David,
Replace flash simms
the system thinks the two chips are of different type.
and also:
I'm afraid you cannot even format the flash because you cannot access it.
Verify that both chips are well seated in the slots.
Hope to help
Giuseppe
Hello Giuseppe,
is there any way to get IOS version back if it accidentally delete?
David
Hello David,
the answer is yes but different ways can be needed depending on the state of the router.
If the router is alive with IOS running you can use the command
copy tftp flash
You need to have the right image on a TFTP server.
otherwise if the device has been reloaded without finding a valid IOS image it will stuck in rommonitor
you should see on the console a prompt like
rommon
for C5320 in this case the file can be placed in the flash using Xmodem on the console connection see
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml
other platforms are able to perform tftp from rommonitor
In any case the first step is to have the right image available on a PC with a TFTP server running
Hope to help
Giuseppe
It is C2600 Router and in rommonitor and there is no IOS in it. I am thinking of using The same Model with the IOS to copy ios from other C2600 to the deleted IOS c2600 by using Crossover cable with same subnet.
David
Hello David,
it should work
Best Regards
Giuseppe
it is not working.
Still
on rommonitor.
David
Use this:
rommon 1> IP_ADDRESS=172.15.19.11
rommon 2> IP_SUBNET_MASK=255.255.255.0
rommon 3> DEFAULT_GATEWAY=172.16.19.1
rommon 4> TFTP_SERVER=172.15.20.10
rommon 5> TFTP_FILE=/tftpboot/c2600-i-mz
what does the dir flash: command give ? does it show a valid IOS ? rommon has limited configuration information, and you should be able to restore from it. have a look at this doc.. might help you:
http://www.cisco.com/en/US/docs/routers/access/2600/hardware/installation/guide/2600appB.html
Hope this helps
Raj
This is a lab router without any connection to TFTP server and i do not think i need default gateway i am thinking of loading it from another same model. But no live connection it is a stand alone router , is for Team Lab.
Any other suggestion would be appreciated
