Remote chage outside ip address for ASA5505
phantomorg
Hi guys! Help me with remote changing ip address for my ASA5505.
     Detail:
interface Vlan1
     nameif inside
     security-level 100
     ip address 192.168.1.7 255.255.255.0
interface Vlan2
     nameif outside
     security-level 0
     ip address 11.155.11.77 255.255.255.224
George Horton
Changing the IP address of a firewall, or for that matter any device, all depends on what access you have to the network.
For instance you may have a VPN which bypasses the ASA and allows you access to the management network, or a console server which can be dialed up.
If you are relient on accessing the firewall via it's public IP then I would suggest either being on-site, or having someone trustworthy there to to the work on your behalf.
