WAN Failover with Cisco2911 IOS version 15.1.4M
georgievh
Hi All,
I thing that i find some bug in the newest IOS 15.1.4M.
The case is falow:
I start to configure failover for the costomer - make default route, make the default path but i cant find the comand IP SLA monitor.
Is some meet this problem with this IOS or just Cisco make some chenge in the CLI commands?
Tomorrow i will try with IOS version 15.1.1T.
raparash
what license set do you have installed on the router?
i believe you would need "ip data" license installed on the router for this command to be supported.
you can check whether you have the right license file or not in the "show version" or the "show license all" outputs.
raparash
Oh did not see that this command is in the Data License.
10x
how i can make Failover between the WAN interface withaut IP SLA ?
I want to wach the interface if is down logical ( not phisical  ) ?
