Remote config of router over Frame-Relay
cromo
There used to be a way to configure and up stream router to supply an IP address to a new down stream router and then allow tftp of the config. Is this still supported? I cannot find a document on how to set this up.
I believe you may be referring to the auto install over frame relay feature.
Have a look at this link.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080087ba5.html
Sundar
Sundar,
Thanks for your reply. While the specific web page did not provide the exact configuration I needed, it did point me in the right direction.
Chris
Chris,
I guess it's not a popular feature from the fact there isn't much documentation available on the web. I remember having done a lab on this a long time ago and indeed it works the way it's supposed to do :) Just play with it in a lab environemnt and let us know how you do.
Sundar
