Hi Guys,
I have a question regarding Remote Intelligent Mirroring, if my network design has a solution including a core switch and multiple edge switches and the core switch has embedded this service RIM which I can mirroring any other port on the edge switches, it's a must to have on the edge switches RIM embedded?
It will be a considerable cost cut if the core switch can do this, having a edge switch without RIM.
Thank you.
Iulian
