Cant trace route by one interface out of 2 ebgp interface from single Cisco router
i have a scenario where i have one cisco router and 2 ISP (A and B for example) connected by 2 eBGP . So when i do show ip bgp , i get *> from ISP A and * from ISP B now when i do traceroute to a reachable ip taking source the interface of ISP B the results not come and all i see is * * * , but when i do traceroute by taking source the ISP A router interface then the traceroute results come . So my question is why i can't get traceroute out put from other interface by making as source .
Hello
Looking in the bgp table can show you multipaths entries to the same prefix but by default  only the best bgp preferred route will be entered in the route table and by the sounds of it ISP A is your preferred wan interface for this prefix.
*> Valid entry and preferred best path
*  Valid entry
Sounds like ISP B interface isnt known for traceroute to reply.
Are you advertising your connected interfaces in bgp?
Kind Regards
Paul
Thanks Paul for your rever , and yes in router bgp <ASN> there is redistribute connected and yes the same routes are advertised in both the ISP , but the cef table entry with only ISP A , and i cant able to trace-route from ISP B making that interface as source .That is the issue i want to clear about .
Also getting bgp neigbor route receive from both the ISP's
