CSR Generation on ASR 1001x
Joe Bloggs
Hi Trying to generate a CSR for a new trust point I've created on my ASR 1001x Router and I'm getting this error?
crypto pki trustpoint ACME
enrollment url http://192.168.1.1:80
fqdn mysite.acme.com
subject-name C=UK, ST=Pall Mall, L=London, O=Acme, OU=LAB, CN=mysit.acme.com
vrf FrontDoor
revocation-check none
rsakeypair ACME-KEY 2048
crypto pki enroll ACME
% You must authenticate the Certificate Authority before
you can enroll with it.
Any ideas why this is happening the router is fresh out of the box. The only other crypto commands to have been issued are:
crypto key generate rsa general-keys modulus 2048
The default crypto trustpoints are still configured.
Trustpoint CISCO_IDEVID_SUDI:
Trustpoint CISCO_IDEVID_SUDI0:
Trustpoint TP-self-signed
Dennis Mink
I am assuming you are trying to enroll to a CA (192.168.1.1) that is external to your ASR, in otherwords, you will need to authenticate this external CA. this is so the ASR actually trusts the CA before it enrolls
check this URL:  https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/security/a1/sec-a1-xe-3se-3650-cr-book/sec-a1-xe-3se-3850-cr-book_chapter_0101.pdf
Please remember to rate useful posts, by clicking on the stars below.
Dennis Mink
Ah you've pointed me in the right direction. I see the issue now.
