Remove AS from outbound best path selection
blacksnow94
Hi there!
We have an ASR 9001 that I'm wanting to better balance our outbound traffic for.
Our setup is as follows
Router -> Tier 1 ISP X
Router -> BGP peer with another public ASN -> Tier 1 ISP Y
It was easy to balance the incoming traffic, I simply prepended our ASN once to ISP X, however I'm having a difficult time balancing outbound traffic.
Ideally what I'd like to do is simply strip out the ASN that's in the middle of going to ISP Y so that BGP bestpath is more accurate. However I have not found a way to do this, as it's a public ASN.
Any assistance or ideas would be appreciated.
Thanks!
Hello
@blacksnow94 wrote:
Thanks Paul, I appreciate the assistance. Would this failover to the other ISP if said ISP it's set as the next-hop to failed? It doesnt seem like it to me, but I could be wrong.
Hello
A rudimentary resilience for pbr would be to specify a second next hop in the same route
map or you could apply some ip verification on the tracking which is a little more configuration but a lot more deterministic
ip sla 10
icmp-echo <next-hop>
ip sla schedule 10 start-time now life forever
track 10 rtr 10 reachability
route-map xx
set ip next-hop verify-availability <next-hop>
Kind Regards
Paul
16 Replies 16
you cannot strip a public AS number from the AS path. Why don't you simply use weight ?
Hello @blacksnow94
If this is a single router with dual ebgp peering then as stated you can utilize the bgp weight path attribute (which isn't really a PA) to engineer egress traffic based on various criteria such as an access/prefix list or as-path regular expression.
See attach file for example:
Kind Regards
Paul
Hi Paul,
Thanks, I appreciate the assistance. Yes, it's a single router connected to two eBGP peers. Perhaps I'm missing a concept with weighting, but the weight I have tried to set simply forces it all out one peer or another, it does nothing to balance it. Below is what I've tried for my BGP neighbors:
 neighbor xxx.xxx.xxx.xxx
  remote-as ISP1/X
  description ISP1
  local address 123.456.78.10
  update-source Bundle-Ether1.2039
  address-family ipv4 unicast
   weight 400
   route-policy ISP1-in in
   allowas-in 1
   route-policy ISP1-out out
   soft-reconfiguration inbound
neighbor yyy.yyy.yyy.yyy
  remote-as ISP2/Y
  ebgp-multihop 10
  description ISP2
  local address 123.456.78.9
  update-source Bundle-Ether1.2038
   weight 500
   route-policy ISP2-in in
   allowas-in 1
   route-policy ISP2-out out
In this configuration all traffic is forced out ISP2.
My route-policies are pretty ordinary, outbound I have if destination is in our prefix lists then pass, else drop and for ISP X I have a prepend 1 time.
Hello
That is  because you have a weight preferential for the whole peering for isp2  to be preferred over isp1, review the example i provided and apply the similar concept lon that software which looks like ios-xe?
Kind Regards
Paul
Hi Paul,
Yeah, IOS-XR (ASR 9001). Based on your example it looks like you're matching the ASN, which to me seems it would do the same thing as applying to the neighbor, unless I'm missing something. Both peers are sending a full route table. So if I set a weight of 500 to match the AS of ISP 1 and a weight of 600 to match the AS of ISP 2, it'll do the same thing as applying it to the neighbor, or am I missing something there?
Once again, I really appreciate your assistance.
Hello
The weight values are arbitrary those are just examples i provided based on a specific regex attribute such as an specific as-path value in a an advertising prefix or access-control/prefix lists match
Basically with this weight PA you can be quite deterministic in your egress path selection using this form of configuration so if you have a certain route advertised from both isps and you would like to use via a certain ebgp peer to reach that route then you can do this just using the weight path attribute.
Kind Regards
Paul
Hi Paul,
The prefixes are advertised out each peer so that it's multi-homed. It sounds like using the weight attribute I would just have to split up my prefix lists and set half of them to prefer ISP 1 and half of them to ISP 2 to get some sort of balance.
I was hoping to have a better bestpath determination, actually comparing the number of ASN's (minus one) but it sounds like that's not possible.
Hello
Can you elaborate on how you wish to LB your traffic, path determination based on weight and regular expression can be very powerful however it depends on what you’re looking for.
Another alternative could be to implement performance edge routing, Which can optimize your traffic path based on monitoring results of traffic flow/volume etc…) here
Kind Regards
Paul
That's an interesting idea, I have not played with performance edge routing before. I'll definitely have to lab that out.
All I was trying to do was balance out the outbound traffic a bit better using as-path determination. Prepending a single AS worked nearly perfectly for inbound, so was hoping to do something of the same inbound, either prepending once outbound to the direct Tier 1, or removing the ASN that's in the middle for ISP Y.
in addition to the other posts, have a look at topolofy 4 in the attached document...
https://showipbgp.com/sample-cisco-bgp-configuration-by-topology/
Alright, so based on ya'lls suggestion I'm trying a different route here.
I would like to weight a prefix-list of locally originated subnets to prefer ISP Y, however I'm struggling with the syntax for the route-policy.
Since weight is not an allowed outbound set command for route-policy in IOS XR, what is the proper syntax to use? I was assuming something like:
route-policy V4-ISPY-TO
if source in V4-PREF-ISPY
set weight 200
endif
... other rules
end-policy
However, that's not something that's allowed for an outbound policy. Any ideas on how to do that?
Hello
fyi you cannot advertise the weight PA - weight is only read locally on the rtr - you can set weight on prefixes being received by the rtr but not being advertise by it .
As you have discovered as-path prepending is a preferred way of advertising suggested ingress paths for the ISP peers either when this is based on all local originated or locally selected prefixes path determination can be accomplished.
For egress path determination you can utilise the weight pa only on a single bgp rtr with multiple egress paths but additionally you could also use regular expressions based on the any received prefixes as-path attributes.
However you won’t be able to remove the as-path information from any received ebgp prefixes
Kind Regards
Paul
Thanks, yeah so now what I'm trying to do is prefer one BGP peer, egress, for a local prefix-list of source subnets. Is there a way to do that?
Hello
Ingress traffic
Advertise those specific local subnets to either isp peers and as-path prepend on them towards the less preffered path (this would be for the return traffic)
Egress traffic
Policy base route on those specific local subnets towards the preffered ISP peer.
See attached file for an example:
Kind Regards
Paul
