remove the following (ip nat translation) from Configuration
Mohamed246
I want to remove the following (ip nat translation) from Configuration on my Cisco C1111 router
Pro Inside global Inside local Outside local Outside global
tcp 41.128.245.170:59538 192.168.1.89:59538 157.185.188.1:443 157.185.188.1:443
i am try this command
no ip nat inside source static tcp 192.168.1.89 59538 41.128.245.170 59538 outside source static tcp 157.185.188.1 443 157.185.188.1 443
but i got this message
% Invalid input detected at '^' marker. (refer to outside in the command)
i need help to remove this
Hello
the OP stated you wish to delete what seems to be a static Nat statement and presently you are not able to do so
So can you post the Nat configuration and if need be remove/hide the public addressing if any is showing
Kind Regards
Paul
7 Replies 7
post the running configuration of your router.
You can only type:
--> no ip nat inside source static tcp 192.168.1.89 59538 41.128.245.170 59538
-->no ip nat outside source static tcp 157.185.188.1 443 157.185.188.1 443
as two different lines...
hello
try the following:
no ip nat inside source static tcp 192.168.1.89 59538 41.128.245.170 59538 extendable
Kind Regards
Paul
Thank you for reply,
But i Got the message "%Translation not found"
Hello
Can you post the output:
sh run | in nat
sh ip nat nvi translations
sh ip nat translations
Kind Regards
Paul
the output of these commands showes all the ports which I have opened in my router ,so it is a critical data i cannot post it as a public
I have cleared it from the screenshot,
I think that the translations which are outside are opened by the router automatically to allow users to access internet sites like facebook and google ,etc ... , right  ?
Hello
Kind Regards
Paul
Thank you Mr. Paul.
