GLBP not working between two switches
Hello guys.
I have connected two switches directly to each other over a trunk link on Ethernet0/0, i have then created VLAN 200 in both switches and configured Interface VLAN 100 with an IP address and GLBP group IP address, the configuring is a minimimal GLBP configuration, the problem is that the GLBP is not communicating over the trunk link, each switch is selecting itself as active and does not see the other switch, what could be the problem, see configuration and output below:
Switch 2:
interface Ethernet0/0
switchport mode trunk
duplex auto
CORE-SWITCH-02#sh run int vlan 200
interface Vlan200
ip address 192.168.200.3 255.255.255.0
glbp 200 ip 192.168.200.1
Switch 1:
duplex auto
CORE-SWITCH-01#sh run int vlan 200
interface Vlan200
ip address 192.168.200.2 255.255.255.0
CORE-SWITCH-02#sh int trunk
Port Mode Encapsulation Status Native vlan
Et0/0 on 802.1q trunking 1
Et0/1 on 802.1q trunking 1
Et0/3 desirable n-isl trunking 1
Port Vlans allowed on trunk
Et0/0 1-4094
Et0/1 1-4094
Et0/3 1-4094
Port Vlans allowed and active in management domain
Et0/0 1,100,110,200
Et0/1 1,100,110,200
Et0/3 1,100,110,200
Port Vlans in spanning tree forwarding state and not pruned
Et0/0 1,100,110,200
Et0/1 1,100,110,200
Et0/3 1,100,110,200
CORE-SWITCH-02#sh glbp brief
Interface Grp Fwd Pri State Address Active router Standby router
Vl200 200 - 100 Active 192.168.200.1 local unknown
Vl200 200 1 - Active 0007.b400.c801 local -
14 Replies 14
do you have 'ip routing' enabled on both switches ? If possible, post the full running configs of both switches...
@Georg Pauwen yes, "ip routing" is enabled on both switches
can both switches ping each other's IP address ?
balaji.bandi
i suggest to add on the primary :
glbp 200 priority 110
glbp 200 preempt
also check on both the switch  do you have vlan 200 created : post below output
show vlan
show span vlan 200
shw ip interface brief
show glbp 200
BB
@balaji.bandi  i have added the priority and preempt commands on primary, but not seeing each other yet.
below are the command output
Switch 1:
CORE-SWITCH-01#sh vlan
VLAN Name Status Ports
1 default active Et0/2, Et1/0, Et1/1, Et1/2
Et1/3, Et2/0, Et2/1, Et2/2
Et2/3, Et3/0, Et3/1, Et3/2
Et3/3
100 ASA-01 active
110 ASA-02 active
200 USERS active
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
100 enet 100100 1500 - - - - - 0 0
110 enet 100110 1500 - - - - - 0 0
200 enet 100200 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 tr 101003 1500 - - - - - 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trnet 101005 1500 - - - ibm - 0 0
Primary Secondary Type Ports
CORE-SWITCH-01#sh span vlan 200
VLAN0200
Spanning tree enabled protocol ieee
Root ID Priority 32968
Address aabb.cc00.0100
Cost 100
Port 1 (Ethernet0/0)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32968 (priority 32768 sys-id-ext 200)
Address aabb.cc00.0200
Aging Time 300 sec
Interface Role Sts Cost Prio.Nbr Type
Et0/0 Root FWD 100 128.1 Shr
Et0/1 Desg FWD 100 128.2 Shr
Et0/3 Desg FWD 100 128.4 Shr
CORE-SWITCH-01#sh ip int brief
Ethernet0/0 unassigned YES unset up up
Ethernet0/1 unassigned YES unset up up
Ethernet0/2 unassigned YES unset up up
Ethernet0/3 unassigned YES unset up up
Ethernet1/0 unassigned YES unset up up
Ethernet1/1 unassigned YES unset up up
Ethernet1/2 unassigned YES unset up up
Ethernet1/3 unassigned YES unset up up
Ethernet2/0 unassigned YES unset up up
Ethernet2/1 unassigned YES unset up up
Ethernet2/2 unassigned YES unset up up
Ethernet2/3 unassigned YES unset up up
Ethernet3/0 unassigned YES unset up up
Ethernet3/1 unassigned YES unset up up
Ethernet3/2 unassigned YES unset up up
Ethernet3/3 unassigned YES unset up up
Vlan1 unassigned YES unset up up
Vlan100 10.2.2.108 YES manual up up
Vlan110 10.2.2.116 YES manual up up
Vlan200 192.168.200.2 YES manual up up
CORE-SWITCH-01#sh glbp
Vlan200 - Group 1002
State is Active
1 state change, last state change 00:39:19
Virtual IP address is 192.168.200.1
Hello time 3 sec, hold time 10 sec
Next hello sent in 1.792 secs
Redirect time 600 sec, forwarder timeout 14400 sec
Preemption enabled, min delay 0 sec
Active is local
Standby is unknown
Priority 200 (configured)
Weighting 100 (default 100), thresholds: lower 1, upper 100
Load balancing: round-robin
Group members:
aabb.cc80.0200 (192.168.200.2) local
There is 1 forwarder (1 active)
Forwarder 1
State is Active
1 state change, last state change 00:39:08
MAC address is 0007.b403.ea01 (default)
Owner ID is aabb.cc80.0200
Redirection enabled
Preemption enabled, min delay 30 sec
Active is local, weighting 100
Switch 2
CORE-SWITCH-02#sh vlan
Et3/3
100 ASA-01 active
110 ASA-02 active
200 USERS active
CORE-SWITCH-02#sh span vlan 200
VLAN0200
This bridge is the root
Aging Time 300 sec
Et0/0 Desg FWD 100 128.1 Shr
CORE-SWITCH-02#sh ip int brief
Vlan100 10.2.2.109 YES NVRAM up up
Vlan110 10.2.2.117 YES NVRAM up up
Vlan200 192.168.200.3 YES NVRAM up up
State is Active
1 state change, last state change 00:37:20
Next hello sent in 2.688 secs
Preemption disabled
Active is local
Standby is unknown
Priority 100 (default)
Group members:
aabb.cc80.0100 (192.168.200.3) local
Forwarder 1
State is Active
1 state change, last state change 00:37:09
Owner ID is aabb.cc80.0100
Redirection enabled
Hello @vitumbiko nkhwazi ,
as we can see on the output
of show spanning-tree vlan 200
Switch02 is the root bridge for VLAN 200 and Switch01 has as root port eth0/0
Please note if these are two Nexus you need in global config:
feature glbp
Hope to help
Giuseppe
@Giuseppe Larosa they are not Nexus switches, they are Cisco IOU L2 switches running in GNS3, version 15.1
What is the devices here, what IOS code running, Can you shutdown the vlan interface 200 and bring up.
Just did a quick testing based on your config here is my results (i used 300 vlan instead of 200)
BB
@balaji.bandi these are Cisco IOU L2 switches running in GNS3, version 15.1, shutting down the interfaces and bringing them back up does not resolve the issue.
Try different version latest one 15.2 onwards, i tried on PNET lan sale IOL works as expected.
BB
post the output of:
show ip route
from both switches.
Can you try disabling IGMP snooping on the switches ie. "no igmp snooping".
I have seen it in the past where HSRP etc. does not work until you do that.
Jon
Hello
Basicaly you dont have L3 connectivity between sw1-sw2!
Is the physical connectivity correct, Have you created vlans for vlan 200 on both swithes, is the SVi up on both siwthes?
Kind Regards
Paul
@paul driver i have confirmed L3 connectivity, SVI's are up on both ends, see ping from SW1 to SW2 below
CORE-SWITCH-01#sh ip int brief | in Vlan200
Vlan200 192.168.200.2 YES NVRAM up up
CORE-SWITCH-01#
CORE-SWITCH-01#ping 192.168.200.3
Sending 5, 100-byte ICMP Echos to 192.168.200.3, timeout is 2 seconds:
Success rate is 80 percent (4/5), round-trip min/avg/max = 1/3/9 ms
