05-06-2019 06:13 AM
Hi All,
Recently upgraded a C3650 switch by copying the bin file to the flash, upgrade was successful
but once I power cycle the device it is looking for the bin as the default boot variable
"System is unable to boot automatically. The boot environment variable needs to be set"
below is the show boot result
Current Boot Variables:
BOOT Variable = flash:*******.bin;flash:pacakges.conf
Boot Variables on next reload:
Manual Boot = no
Boot Mode = no
Boot Mode= Device
05-06-2019 09:51 AM
05-06-2019 09:54 AM
Try Post the output or check all the images available in the flash:
dir flash:
05-06-2019 11:50 PM
please find the output
switch: dir flash:
Directory of flash:/
62081 drwx 4096 .
2 drwx 4096 ..
62082 -rw- 83293932 cat3k_caa-base.SPA.03.06.06E.pkg
62083 -rw- 3982012 cat3k_caa-drivers.SPA.03.06.06E.pkg
62084 -rw- 33788908 cat3k_caa-infra.SPA.03.06.06E.pkg
62085 -rw- 43074880 cat3k_caa-iosd-universalk9.SPA.152-2.E6.pkg
62086 -rw- 28394380 cat3k_caa-platform.SPA.03.06.06E.pkg
62087 -rw- 111233856 cat3k_caa-wcm.SPA.10.2.160.0.pkg
62089 drwx 4096 dc_profile_dir
62091 -rw- 2097152 nvram_config
62092 -rw- 676 vlan.dat
62093 -rw- 1236 y
62094 -rw- 222 bootloader_evt_handle.log
62095 drwx 4096 core
23282 drwx 4096 .prst_sync
38801 drwx 4096 .rollback_timer
62097 drwx 4096 gs_script
62098 -rw- 65568 memleak.tcl
62099 drwx 4096 .installer
62100 -rw- 2097152 nvram_config_bkup
62105 -rw- 15938176 cat3k_caa-guestshell.16.03.08.SPA.pkg
62110 -rw- 22306197 cat3k_caa-rpbase.16.03.08.SPA.pkg
62106 -rw- 264487544 cat3k_caa-rpcore.16.03.08.SPA.pkg
62108 -rw- 9671296 cat3k_caa-srdriver.16.03.08.SPA.pkg
62109 -rw- 209578612 cat3k_caa-wcm.16.03.08.SPA.pkg
62107 -rw- 13439612 cat3k_caa-webui.16.03.08.SPA.pkg
62104 -rw- 4742 packages.conf
776814592 bytes available (873271296 bytes used)
05-07-2019 10:08 AM
05-08-2019 12:15 AM
