Bandwidth limitation on Router ISR4431
2004anand
Hi All,
I have single ISP used for two project, I have configured subinterface on router lan interface for projects.
Now i am want to apply rate limit for bandwidth on interface for specific project, Kindly share configuration for bandwidth limitation.
Router:ISR4431
IOS:X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.4(3)S4
Please let me know any additional information required.
Thank You.
Julio E. Moisa
You can configure police or traffic shaping to limit bandwidth, please see the following links to know the proper configuration:
https://supportforums.cisco.com/discussion/10956426/limiting-bandwidth-cisco-router-possible-1800-series
http://packetlife.net/blog/2008/jul/30/policing-versus-shaping/
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
D_Lebedev
Level 3
Level 3
This is my config.Limit is 3mbit/s
And you can change it as you need.
Hope it helps
mls qos
class-map match-all rate-limit
description Bandwidth Control
match ip dscp default
policy-map 3meg
class rate-limit
police 3072000 192000 exceed-action drop
int faX/Y
service-policy input 3meg
in addition to the other posts, you could also rate limit directly on the interface. This example would limit traffic to 20Mbit:
interface GigabitEthernet0/0.1
 rate-limit output 20000000 3750000 7500000 conform-action set-prec-
transmit 5 exceed-action set-prec-transmit 0
FYI - ISR 4331 etc don't support the 'rate-limit' command, which is likely why the original poster was asking
