Removing dialer from Fast Ethernet 0/0 port on Cisco 1841
martingeorge123
Dear All,
I am pretty new to Cisco.
I want to remove the dialer configured on Fast Ethernet 0/0 (WAN Port) and to put the ip address 192.168.10.10/24  on that port, which is coming from ISP with internet configured.
Please help. Find the current configuration:
Current configuration : 1950 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 $1$hStT$idERcNp2LY9.BbNF//Tbw/
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip domain retry 5
ip domain timeout 6
ip name-server 213.42.20.20
ip name-server 195.229.241.222
username admin privilege 15 password 0 system
archive
log config
hidekeys
interface FastEthernet0/0
description WAN Connection
no ip address
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 5
interface FastEthernet0/1
description Connected to LAN
ip address 192.168.0.254 255.255.255.0
ip nat inside
duplex auto
speed auto
interface ATM0/0/0
no ip address
shutdown
atm restart timer 300
no atm ilmi-keepalive
interface Dialer0
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 5
dialer remote-name etisalat
dialer idle-timeout 0
dialer persistent
dialer-group 10
ppp pap sent-username tiganih password 0 7irnghz3
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 192.168.0.0 255.255.0.0 192.168.0.1
no ip http server
no ip http secure-server
ip dns view default
domain timeout 6
domain retry 5
ip nat translation timeout 600
ip nat translation tcp-timeout 600
ip nat translation icmp-timeout 600
ip nat inside source list 130 interface Dialer0 overload
access-list 10 permit 192.0.0.0 0.255.255.255 log
access-list 130 permit ip 192.168.0.0 0.0.255.255 any
dialer-list 10 protocol ip permit
control-plane
line con 0
line aux 0
line vty 0 4
password system
login local
transport input all
scheduler allocate 20000 1000
end
Seb Rupik
Try the following:
default interface fa0/0
int fa0/0
  desc WAN Connection
  ip address 192.168.10.10 255.255.255.0
  ip nat outside
  duplex auto
  speed auto
int dialer0
  shutdown
no ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 0.0.0.0 0.0.0.0 fa0/0
no ip nat inside source list 130 interface Dialer0 overload
ip nat inside source list 130 interface fa0/0 overload
Do you know the IP of the ISP router? If so, append that IP to the ip route statement
ip route 0.0.0.0 0.0.0.0 fa0/0 <ISP_ROUTER>
cheers,
Seb.
5 Replies 5
Seb Rupik
Try the following:
int fa0/0
  desc WAN Connection
  ip nat outside
  duplex auto
  speed auto
int dialer0
  shutdown
cheers,
Seb.
Thanks a lot Mr. Seb Rupik. I will check and update you. I think that it will work properly.
Can I ask you a doubt, will it show the following error:
"%Remove dialing ddb from profile first".
Its just a doubt.
Should remove the dialer-group association with the dialer0 interface. After doing that you could try the following:
int dialer0
no dialer pool 5
no dialer-group 10
shutdown
Are you actually seeing the "%Remove dialing ddb from profile first". error message?
cheers,
Seb.
No,I haven't tried it yet as the router is in another place. Its just a doubt.
I will check in the evening and will get back to you.
You are the best.
Thanks a lot man. Its working fine.
Many Thanks,
Martin George.
