08-27-2013 08:30 AM - last edited on 03-25-2019 03:39 PM by ciscomoderator
Can i change the power supply in a 2911 router that is running with a AC power supply for a DC power supply.
Thanks and regards,
Solved! Go to Solution.
08-27-2013 09:44 AM
08-27-2013 10:11 AM
Hi Jose,
Please check this below URL to replace PS Unit:
Please rate if it is helpful.
Mithun Adhikary
08-27-2013 09:44 AM
Yes.
08-27-2013 10:11 AM
Hi Jose,
Mithun Adhikary
01-04-2019 05:00 AM
With a 2911 which has an RPS unit connected, is the AC PSU Hot-Swappable ? I believe it is but cannot find written documentation to support it.
The following document specifically mentions that the 2921 and 2951 can be hot-swapped https://fccid.io/ANATEL/00548-10-01086/Manual-parte-3/59E875C8-EF90-46BB-A3D3-5D241A6C4328/PDF (on page 5-27)
01-14-2019 07:31 AM
Bump - anyone ???
