Replace ISR 2821 with Cat 3850
Nayan.Patel85
I want to Replace ISR 2821 with Cat 3850
What parameters should be taken into Account.
thanks
Vignesh Rajendran Praveen
Hi Nayan,
While this question is very broad I have managed to provide a couple of links below and a quick read would prove handy.
http://www.cisco.com/c/en/us/support/switches/catalyst-3850-series-switches/products-installation-guides-list.html
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3850-series-switches/data_sheet_c78-720918.html?cachemode=refresh
***********Plz do rate this post if you found it helpful*************************
Thanks & Regards,
Vignesh R P
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of   the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Well, for starters, any features being used on the 2821 that are not found on the 3850.  Also, how large a route table is being used by the 2821.  (The former should be able to deal with full Internet route tables, but the 3850 might be unable to do so.)
