Replace two routers and 1 switch with 1 catalyst 2960
OraWiz
I currently have two routers and one switch with 2 vlans.  Is it possible to configure a catalyst 2960 to replace all three?
Switch configuration:
vlan 1: Ports 1-15
vlan 2: Ports 16-20
vlan 1 - IP range is 10.10.10.0 255.255.255.0
vlan 2 - IP range is 69.25.25.0 255.255.255.0
Router 1 IP addresses are 10.10.10.1 and 10.10.9.2
Router 2 IP addresses are 69.25.25.1 and 69.30.20.78
How would I configure the 2960 to be able to route traffic from 10.10.10.0 to 10.10.9.1
and route traffic from 69.25.25.0 to 69.30.20.73
balaji.bandi
yes it is possible, but what is the role of 2 routers, is this high availability ?
if you replace with 1 switch you will not get that resilience.
So explain more about exiting setup in detailed.
BB
Joseph W. Doherty
I believe that depends on the model of 2960 and its IOS version. Some 2960 models, I believe, only support L2 while some 2960 models (I think starting with the 2960S series) support some very limited routing.
